Old 09-06-2017, 09:03 PM
Default Here
If you look at
http://www.mykitlog.com/users/catego...category=10063
You will see what I did. I changed the tee to one with a npt pipe thread and then used a fumoto quick drain. The details are in my kit log and I think it will work well...
See the 6-12-2017 entry referencing the oil pickup line, first photo
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 09-07-2017, 07:58 AM
Plummit's Avatar
Plummit Plummit is offline
What thread sealant did you use on the tee-to-sump NPT threads?
-Marc
Originally Posted by rocketman1988 View Post
If you look at
N814RV
2018 Donation made!
Old 09-07-2017, 08:39 AM
Default Sealant
I used Loctite 567. Longer cure time for adjustment, high temp, and not affected by petroleum products...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 09-07-2017, 11:38 AM
henke@mweb.co.za henke@mweb.co.za is offline
Talk to Tom @ tsflightlines. He supplied a fitting that connects to the t-nut so I can screw quickdrain on
Regards
Henke
RV 10 builder
Old 09-07-2017, 03:57 PM
Default Replacement Tee
The Tee I used was a standard hydraulic fitting that has one male 1/2" NPT and two female 1/2" NPT ports. Cost was about $6...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
