Old 01-11-2017, 08:02 PM
ricardoramos's Avatar
ricardoramos ricardoramos is offline
Originally Posted by Jared_Solomon View Post
It's pretty easy to adapt the ADHRS mount in the left wing for the GMU-22. It's also fits nicely with the Van's wiring. The Garmin part you need is:
Garmin GMU-44 Universal Mount Kit P/N: 011-01779-01
You can find them on ebay brand new for pretty cheap. However I would recommend getting your hands on the GMU-22, or at least the mounting ring that comes with it prior to closing up the wing. The mounting ring (included with the GMU-22) needs to be riveted to the Garmin bracket, which is riveted to the ADHRS bracket. I can take some pictures of my install and send them to you if it would be helpful.
I am considering installing mine on a deck in the junction on F-01407 bulkhead and F-14131 fuse rib but this wing mounting option is very attractive. I wonder if the wingtip/landing lights cabling won't interfere with the proper operation of the GMU-22 since they run nearby and carry moderate and intermittent currents, like landing lights and led strobes.
Ricardo Ramos
RV-10 PR-ZNM | http://www.rv10.com.br
RV-14A PR-ZNV | http://www.rv14.com.br
SWIT - 25 29 9S/54 26 30W
BRAZIL
Old 01-11-2017, 08:10 PM
1001001's Avatar
1001001 1001001 is offline
I think an optional kit and drawing is about to be released that will cover this.
Will this be applicable to the -10 as well?
Old 01-11-2017, 09:46 PM
gen1313 gen1313 is offline
Ricardo, I had interference from the strobe initially. I was advised to make sure all wing lights were grounded back to the fuse which fixed the problem.
Graham Haley
RV-14 #140181
Flying 5th January 2017
70+hours now
Old 01-11-2017, 10:17 PM
No
It is specific to a mount tray that gets built into the RV-14 wing during construction. Adding it afterwards would be difficult.
Scott McDaniels
Hubbard, Oregon
Old 01-12-2017, 05:57 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Next best location for mag mount ?
No
Looked, but do not find this addressed >>
My 14 wings are complete. Is there a recommended next best place to mount the Magnetometer than the ADHRS mount already in-place in the wing?
Jeff Warren
Simpsonville, SC (SC47)
1946 Bellanca Cruisair 14-13-2 (71 YRS OLD 8/15/17)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 01-12-2017, 07:08 PM
JHartline JHartline is offline
Default Take a look at this thread for alternate location
Search for "GMU22 Mount" on 9/16/2016. I'm not sure how to paste a thread link.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 09-04-2017, 04:11 PM
JDA_BTR JDA_BTR is offline
Rejuvenating this thread because....
I wonder if anyone has any issue with the lights or the pitot heat from a GMU22 in this wing location. I'm using the standard kit-supplied wiring. Should I expect any problems? I figure that if Van's supplies the wiring with the wing kit, and says to put the GMU22 on the bracket, all should be well. But?
N1463 seems a good number....
Old 09-04-2017, 05:19 PM
KeithB KeithB is offline
It would be a good idea to read this thread.
http://www.vansairforce.com/communit...ter+pitot+heat
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >180 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
