Old 01-07-2017, 09:00 PM
Originally Posted by JHartline View Post
Mitch - is there a section in the plans that describes using the AHARS mount for the GMU22? My wings are fully skinned but I believe there is plenty of access room to do whatever I need to do. Mainly curious if adding the GMU mount is an easy task and if I can source the materials from Vans.
Jared - just saw your post as I was finishing mine. I'll PM you my email if you wouldn't mind sending pictures of the mount.
Thanks, James
I think an optional kit and drawing is about to be released that will cover this.
Scott McDaniels
Hubbard, Oregon
Old 01-07-2017, 10:38 PM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default Picture of the GMU bracket on ADHRS mount
Below is a pic of the Garmin bracket riveted to the the ADHRS mount. The Garmin bracket gets drilled/riveted to the ADHRS mount and the GMU-22 mounting ring gets drilled/riveted to the Garmin bracket. This could all probably be done through the wing root or access panel after the wings are closed up, although riveting the Garmin bracket to the ADHRS mount seem like it would be pretty tricky inside the wing. If it were me and I was trying to do this after the wing was closed up I would probably just mount the Garmin bracket directly to the access panel cover instead of the ADHRS mount.
Jared Solomon
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 01-08-2017, 05:38 AM
MLock MLock is offline
James,
Scott would know better about release of the GMU22 mounting kit which I tested sometime ago. It makes the install and attachment to the wing bracket very easy.
Thanks Scott for chiming in.
Mitchell Lock
President Van's Aircraft
Old 01-08-2017, 01:13 PM
I think the kit/plans mount the GMU brackets to the ADAHRS tray so that it can be slid into the mount in the wing making it easy to remove in the future if ever needed.
Scott McDaniels
Hubbard, Oregon
Old 01-09-2017, 12:18 PM
JHartline JHartline is offline
Thanks guys. I'll check with Vans.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 01-09-2017, 04:47 PM
n982sx n982sx is offline
Let us know what you hear from Van's about availability.
I'm about to take all my big pieces to the airport and I'd like to get the magnetometer installed. I've been waiting for them to finish up the mount.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 01-09-2017, 05:36 PM
Vans says at least a few weeks before anything is released. Unless someone wants to come over and do my fiberglass parts for me I got plenty of other stuff to do while I wait.
Clay - sorry if the thread drifted too far.
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
Old 01-10-2017, 08:58 AM
ppilotmike's Avatar
Default What about strobes and landing lights..
..interference? Is the wing location out in the tip or in the outboard leading edge area? Anyone have a jpeg of the plans for this install location. I would assume it could be used for installation in an RV-10 as well, since the wings are so similar.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 01-11-2017, 06:45 AM
Cwood2000 Cwood2000 is offline
Default Magnetometer
Pardon my ignorance, but what is the need of a magnetometer? I am half way through my left wing build and noticed this conversation and it really caught my eye. I am tentatively planning on a Dynon panel, is there something I should install, while the bottom skin s still off?
Aka YellaDawg
RV4
RV14 in gestation
Old 01-11-2017, 08:48 AM
This discussion is revolving around the Garmin Magnetometer for the G3x system.
I believe the magnetometer is built into the Dynon ADAHRS. If so, you are fine as the standard install is for the Dynon ADAHRS.
Bob Meyers
