Old 02-06-2016, 10:31 AM
PRE911 PRE911 is offline
Default Canopy "peel ply" step
Do I understand correctly that in the final steps of the fiberglass layup, the peel ply layer is applied only to add more resin for a smother finish? Then is the peel ply gently pulled off and discarded?
Thanks in advance,
Rich
Building RV-14A. #140061
RV 14A N2261 flying as of 7/22/16
KDVO Novato, Ca.
Rich
Old 02-06-2016, 10:58 AM
It is primarily added over the top of the glass layup.
With peal-ply in place, capillary action draws resin up and out of the lay-up which will result in all of the weave of the the top layer of glass cloth being fully saturated with resin. Without the peal-ply, the top layer would not be fully saturated and there would be a lot of the weave texture showing (that would have to be either sanded off or further filled with resin).
The peal-ply is pulled off once the resin has fully cured.
The secondary benefit to using the peal-ply is it results in a surface that is fully ready (no other sanding or prep. necessary) for adding more glass layers or coats of resin if needed.
Scott McDaniels
Hubbard, Oregon
Old 02-06-2016, 11:22 AM
thank you very much for your quick response. That makes it very clear!
Rich
KDVO Novato, Ca.
Rich
Old 02-07-2016, 03:08 AM
mike newall's Avatar
And don't forget, peel ply is just Dacron - old scraps of Ceconite are just perfect, if you have end rolls of rib tape - better still as already cut up.
Donated twice in 2017
Old 02-07-2016, 05:41 AM
Ron B. Ron B. is online now
For those new to aircraft building, these products are used on fabric covered aircraft, so perhaps your buddy might have leftovers if he built a fabric covered plane.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 02-07-2016, 10:35 AM
Good tip
It is also mentioned in the RV-14 supplemental videos.
Scott McDaniels
Hubbard, Oregon
Old 08-10-2017, 07:33 PM
doug_rv7 doug_rv7 is offline
Default Excellent Videos
Good tip
Scott,
These videos are excellent. Thanks for putting these together. I'm preparing to do this on my 7. I'm going to lean on these quite heavily.
Also, nice presentation @ OSH17.
Doug
