Old 07-26-2015, 03:12 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Originally Posted by SHIPCHIEF View Post
...you need a #2 Philips screwdriver and a torque wrench for the hub bolts.
The new props are shipping with AN3 bolts and large diameter washers instead of the phillips head #10 screws and small Nordlock washers to hold the front spinner bulkhead to the hub. The newest revision of the install manual reflects this too. Use loctite blue on those 2 bolts. I switched mine out a long time ago after one of the screws backed out, but I also used drilled head AN3 bolts and .020 safety wire in addition to the loctite blue on those two bolts... they ain't coming loose again!
Neal Howard
Airplaneless once again...
Old 08-21-2017, 08:06 PM
smithflys23 smithflys23 is offline
Its been a couple of years since this thread was active. Does anyone have any new opinions on the Sensenich GA prop?
Old 08-21-2017, 08:21 PM
Clint B Clint B is offline
Sent you a pm
Old 08-21-2017, 09:01 PM
Christopher Murphy Christopher Murphy is offline
Originally Posted by Neal@F14 View Post
A crush plate is inapplicable to this prop. The hub does not have long thru-bolts like a wood prop does so there is no way to mount a crush plate. A heavy metal ring bolted to the flywheel is the only way you're going to add rotational weight up front with it.
I have this prop and Sabre made a custom spacer for me. Its 8 inch dia x2.25 solid. 11lbs if I recall.
Ive been very pleased except I had to have it changed to the 180hp version to get enough pitch for my RV4.
Very good performance in all aspects
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 08-22-2017, 06:53 AM
Cm
Thanks for the reply! I'm wondering if the added expense of this prop justifies it vs. the Whirlwind GA. I will say that the Sensenich looks awesome, and the adjustment process seems really easy.
