Old 06-16-2013, 06:32 AM
SHF SHF is offline
Default RTV
The "riviting the rudder" instructions call for a daub of RTV. Some web searching learns that this is a brand name silicone adhesive, not sold in my part of the world. Looking for a replacement can I use any silicone adhesive or should it particularly be a gasket sealant, or something else for that matter.
Can anybody advise please?
thanks Roger.
Old 06-16-2013, 06:51 AM
Mel's Avatar
Mel Mel is offline
A silicon adhesive is fine. Just be sure that it is marked "safe for aluminum".
Many silicon adhesives contain acetic acid that contributes to corrosion.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-16-2013, 08:01 AM
Bob Axsom Bob Axsom is offline
Default Room Temperature Vulcanizing
I use a lot of Dow 736 (red) in the high temperature areas and Dow 732 (black) in other areas on my dark blue airplane. Comes in a tube with a seal in the end that has to be broken and has a separate plastic cone that can be cut to different lengths for controlling the size of the opening. It has very good adhesion and "rubber" qualities when cured (24hrs full cure - skins in minutes). Can be used to: stabilize wire routing through a hole in metal, make flow fillets, etc. When I am making gap seals on parts like strut cuffs that are going to be removed a lot and I don't need the strength of the expensive Dow products I buy some similar "rubber in a tube" from an auto parts store. Great stuff.
Bob Axsom
Old 06-16-2013, 08:22 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Look for "Sensor Safe"
If you go the an auto parts store and don't find a silicone sealant labeled "safe for aluminum", look for one labeled as "Sensor Safe". These are the one that don't have acetic acid in them.
Rick Aronow,
A&P, iRMT
Flying 7A Slider;
RV-12 (ELSA, Dual G3X), SOLD
Highland Village,TX
Old 06-16-2013, 09:48 AM
The one I used was Permatex Ultra Blue, 81724 (77B). It's marked "sensor-safe RTV gasket maker."
The first auto-parts place I stopped at had it.
Old 06-16-2013, 12:07 PM
Karsten's Avatar
Karsten Karsten is offline
In the Netherlands and in Germany you could use Sicaflex-521 UV!
It is ok for aluminum.
Karsten
Karsten
RV-8 QB
Empenage kit almost done
QB-Wings almost done
Fuselage in progress
I paid my =VAF= membership dues for 2016
Old 06-16-2013, 03:53 PM
Walt's Avatar
Walt Walt is offline
Or good ole pro-seal.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 01-31-2017, 11:22 AM
jckonekamp jckonekamp is offline
Default RTV Substitute - UPDATE
Here in Argentina I've found a great substitute from SIKA. Is almost the same (or the same) as the Sikaflex 521 UV. It's called Sikabond AT-Metal, and made in Switzerland. It's a grey hybrid polyurethane silicone, non aggressive to aluminum.
I had some RTV left from a previous plane that I decided not to use because it has been opened last year.
Here are the pictures. Hope it helps.
Old 08-28-2017, 08:05 AM
maniago's Avatar
maniago maniago is offline
Well, this is painting with too broad a brush really. Gotta do the homework. Dow 732 is acetic acid cure, but is used on AL airplanes, is MIL spec and Boeing compliant.
http://www.sealantengineering.com/ca...79/7905593.htm
Mani
Mustang II (FoldingWing) "Firewall Fwd stage.Yea!" IO-360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,(maybe)Echo; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 08-28-2017, 11:33 AM
az_gila's Avatar
az_gila az_gila is online now
Question
Note that RTV is not a trade name it's a shortened description of "Room Temperature Vulcanizing" rubber.
Perhaps something got lost in the translation to EU languages?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
