Old 09-12-2017, 04:20 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default SDS CPI current demand ?
Sorry to bother Ross, but I have searched threads all afternoon without clear results to predict load to size my alternator. I recall comments like 1.1 A @ 2,500 RPM ( per CPI unit ?) and cant find the info in proposed wiring diagrams. So hopefully others can benefit from your comment. How much amperage should be budgeted for ONE CPI firing FOUR plugs at 2700 RPM ? Thanks in advance, Larry
Larry DeCamp
RV-3B flying
RV-4 fastback project in the shop
Clinton, IN
Old 09-12-2017, 04:26 PM
Toobuilder's Avatar
I measured 1.6 amps for a single system (in flight) on my 540 at 2700. Based on that, Id think you wouldn't need to budget more than 2 amps (and that would be fat).
Michael Robinson
______________
Harmon Rocket II -SDS EFI instalation in work
RV-8 - Flying
1940 Taylorcraft BL-65 -flying
PA-20-inspired "family truckster" -in work
Old 09-12-2017, 04:48 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Looking at about 1.2 amps on a four.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 418.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
