Old 09-06-2017, 08:03 PM
rocketman1988 rocketman1988 is offline
Default Here
If you look at
http://www.mykitlog.com/users/catego...category=10063
You will see what I did. I changed the tee to one with a npt pipe thread and then used a fumoto quick drain. The details are in my kit log and I think it will work well...
See the 6-12-2017 entry referencing the oil pickup line, first photo
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Dues Paid 2017,...Thanks DR+
Old 09-07-2017, 06:58 AM
Plummit's Avatar
Plummit Plummit is offline
What thread sealant did you use on the tee-to-sump NPT threads?
-Marc
Originally Posted by rocketman1988 View Post
If you look at
N814RV
2018 Donation made!
Old 09-07-2017, 07:39 AM
Default Sealant
I used Loctite 567. Longer cure time for adjustment, high temp, and not affected by petroleum products...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 09-07-2017, 10:38 AM
henke@mweb.co.za henke@mweb.co.za is offline
Talk to Tom @ tsflightlines. He supplied a fitting that connects to the t-nut so I can screw quickdrain on
Regards
Henke
RV 10 builder
Old 09-07-2017, 02:57 PM
Default Replacement Tee
The Tee I used was a standard hydraulic fitting that has one male 1/2" NPT and two female 1/2" NPT ports. Cost was about $6...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 02-19-2018, 04:03 PM
Dustyone Dustyone is offline
Default Oil screen fitting
I am helping another RV-10 builder who has a BPE IO-540 with cold air induction and I am trying to connect the 10D oil line from the T fitting to the rear of the crankcase.
The problem is that the elbow fitting is 180 degrees out once I torque up the fitting for the 10 D hose ( this elbow is a custom elbow that holds the oil screen supplied by BPE)
Can anyone help with another fitting idea or option to clock this fitting in the correct orientation?
Do all BPE engines with Cold Air Induction have this challenge ?
(edit : I have since resolved the clocking issue,but as this is a serviceable item,the action of removing and re-clocking an NPT fitting on a regular basis is not very desirable option )
It is going to be a ‘royal pain' to service this filter screen .
Ashley Miller
RV-10 #40597
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 400hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 03-04-2018, 04:23 AM
Hoping someone can offer an option to my request
Cheers
Ashley Miller
RV-10 #40597
VH-XTE 400hrs +
Redcliffe,Brisbane
Australia
Old 03-04-2018, 07:57 AM
Plummit's Avatar
I didn't know there was an oilscreen behind that elbow! You are correct that it will be a witch (with a capital "B") to service that screen...
-Marc
N814RV
2018 Donation made!
