Old 08-29-2017, 03:44 PM
Rainmaker's Avatar
Rainmaker Rainmaker is offline
Default RV-7 Subpanel gotcha
Just a watch out for builders down the line...
If like me you have all the forward fuselage structure pulled out as you're making the fuel vent lines be aware of the clearance needed for the lower flange of F-768B where it meets the F-902 bulkhead.
It's not something mentioned in the plans, though I was always wondering why the 45* angle in the vent was there
Anyway, I emailed Van's asking if I could take a little material off the flange to allow clearance. Their recommend was this is structural so remaking the vent line is the preferred course.
It's been a while since making these lines. Get to freshin' up my tube bending skillz!
Matt Mulder
Working in the cabin area somewhere
http://n07m.wordpress.com/
VAF#950
Old 08-29-2017, 05:24 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Since you are using SmugMug, it's easy to embed your photo. Here's your pic:
Carl N.
Arlington, WA (KAWO)
RV-8, 300 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Old 08-29-2017, 05:59 PM
Rainmaker's Avatar
Thanks Carl!
Matt Mulder
VAF#950
Old 08-29-2017, 06:28 PM
wirejock's Avatar
wirejock wirejock is offline
Default Vent lines
Guess I get to remake mine too.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-30-2017, 07:34 AM
Raymo's Avatar
Raymo Raymo is offline
Or do your vent lines like the Rockets do.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 08-30-2017, 01:57 PM
I re-bent the vent lines on mine too! I think I used the same ones and just "recountoured" them a little, as the shape is not important; just getting sufficient clearance is.
Doug
RV-9A "slider"
Flew to Osh in 2017!
Tail number N427DK
Donation made for 2018
Old 08-30-2017, 02:37 PM
John Tierney John Tierney is offline
Your going to have to man-handle those vent lines out of the way when you rivet on the top skin. I wouldn't worry about being too precise with the bends on these small tubes.
John Tierney
Salem, WI
RV-7A - Finish/FWF Kit
N70JT Reserved
