Old 08-06-2017, 04:49 AM
jswareiv jswareiv is offline
Default Fuel Filter Check
Can someone tell me how to check the fuel filter for the annual on the RV-14? I'm not sure what to check for, or if there is anything to do to clean it. Thanks.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW
http://rvbuild214sw.com/
Dues paid to 2018.
Old 08-06-2017, 06:23 AM
Ron B. Ron B. is offline
If I recall correctly, you have to cut the small dia. safety wire then it unscrews and the screen is removable for cleaning if needed. I think this was the unit that I needed to purchase smaller dia. safety wire for, bad memory, but I would know if I was looking at the unit.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-06-2017, 11:20 AM
czechsix's Avatar
czechsix czechsix is offline
I asked the Andair rep at Oshkosh about this and he showed how to disassemble the filter and you can then clean and reassemble it. If in doubt you might email them (if you didn't receive any service instructions with it). The filter uses o-rings to seal it so make sure it is in good shape and do a careful leak check after reassembly. Andair told me new o-rings are available thru A/C Spruce if needed.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 08-06-2017, 12:32 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
There are two if you are fuel injected. One on the suction side of the fuel pump if you have the Andair unit and one in the FI unit bolted to the intake manifold. In my RV-8 the first one is under the left subpanel under the fuel selector switch.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donation Made 7/2017
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 08-07-2017, 08:46 AM
MIGHT be a good idea to have a few spare O'Rings in your inventory for this, just in case.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 08-08-2017, 02:28 PM
Default Thanks to all - I'll check with Andair
Thank you.
Stoney
Dues paid to 2018.
Old 08-17-2017, 08:50 AM
GigAir GigAir is offline
Stoney, After a year of flying, I am curious what if any debris you found in your fuel filter. Any surprises? How many hours?
Greg Novotny
RV14ZP 140209
Phase 1
Tacoma Narrows Airport
Gig Harbor, WA
Dues always gladly paid
Old 08-17-2017, 09:03 AM
I had about 50 hrs. on mine at annual, and zero in the inline filter. Very pleased to see.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-17-2017, 04:24 PM
n816kc n816kc is offline
Default debris
We pulled the filter on my -6 after 2 hours, found a very small amount of debris, but nothing concerning. Checked it at the last 6 annuals and haven't found a thing. Will keep checking anyway.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2018 =VAF= donor
Old 08-17-2017, 05:22 PM
Finding a bit of debris after adding fuel the first time and doing the pre first flight fuel system flush is not unusual. Neither is finding some after a few hours of have been flown.
Regardless of the care taken when building the tanks and assembling the fuel system there will always be a bit of stuff that gets missed.
It is also common that after this initial flushing to never find anything in the screens again.
Scott McDaniels
Hubbard, Oregon
