So I recently bought a Fuji Mini Mite 4 turbine spray system to prime and paint my future aircraft (haven't started yet). While researching painting products I noticed the 3M PPS series 2.0 paint cups (similar to Devilbiss DeKups). I was curious though, since the Fuji turbine system sprays at about 9 psi with a higher quantity of air than a normal HVLP that is closer to 40 psi with a lower quantity of air, is their enough suction to use the paint cups without a pressurization system in the cup. I noticed 3M PPS also sells a pressurized version of the 3M Paint Cup system, but it is significantly more expensive and I would rather not spend the money if I don't need the pressure.
Curious if anyone has experience either with this specific Fuji turbine spray system or a similar system and any of the quick cleanup cup systems like 3M PPS or DeKups. Thanks.
