Old 06-13-2015, 09:16 PM
kdedmunds kdedmunds is offline
Default Rivet Question
So I'm working on the Vertical Stabilizer. This is the rear spar and rivets to the doubler. This rivet got a big smiley face so I drilled a pilot hole to remove it. I then used a slightly larger bit to remove the rivet. Obviously I got off center and drilled the hole a little to the side. I replaced the rivet but don't think this is the way it should be left. Is this a good time for an oops rivet or to I need to order a new spar?
K Edmunds
Old 06-13-2015, 09:20 PM
wirejock's Avatar
wirejock wirejock is offline
Kent
Keep trying on the photo.
Till then, what model? What is the rivet callout? How big is the hole across the widest point?
You may be able to go up a size but without the info above, the gurus here (not me) can't advise.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-13-2015, 09:27 PM
K Edmunds
Old 06-13-2015, 09:37 PM
K Edmunds
Old 06-13-2015, 09:56 PM
wirejock's Avatar
Default Photo
This should work.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-14-2015, 06:51 AM
Default Thanks Larry
What did you do to make them appear? "This should work" is that for the pictures or the rivet? Thanks Again
K Edmunds
Old 06-14-2015, 07:28 AM
Tom023 Tom023 is offline
Kent, if it were me I would definitely try an "oops" rivet. In a couple of cases where I've really mangled things I've gone to a -5 rivet with excellent results, as long as I had the edge distance.
RV14A #140083
Down to last 5%.
2018 Donation
Old 06-14-2015, 08:34 AM
wirejock's Avatar
Default Photos
Kent
No, the comment was there just to fulfill the 100 character minimum.
Your posting had "http://" twice on each photo.
As far as the rivets, they look like they are sitting down in a dimple. Maybe an illusion but I'm not building a 14. I would drill it, measure it and try to move up a size. An ooops rivet may work but you need to be sure before drilling. When in doubt, ask Vans.
Also, when you drill, don't go deeper than the head.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-14-2015, 10:04 AM
sblack sblack is offline
ya the holes all look dimpled. Is that some sort of illusion? I even see the ring that looks like a dimple die was used.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2018
Old 06-14-2015, 10:18 AM
Also, if those are the shop-heads, they look a bit under-set. You can measure them and see if they are acceptable. This reference provides dimensions:
Van's Has it here.
