boulderick
Member
I finally bit the bullet and installed ADSB-out in our RV-6A this weekend. I also put two Garmin G5's in and pulled the vacuum pump, directional gyro and attitude gyro. Pretty easy all around except hooking up the G5 altitude encoder function to the Stratus ESG. I got the wires right (single line from RS232 TX - pin 5 - on the G5 to RS232 RX Altitude - pin 5 - on the Stratus). When I fired up the boxes, I got ----- for altitude on the Stratus, and field elevation on the G5, so I knew they weren't talking.
I called Garmin and experimental support guy told me it wouldn't work. I argued that RS232 is a standard, and it "should" work. Called Greg at the Stratus installation support line and he didn't know how to hook the two boxes together . . .
So, I started looking for a way to change communications settings.
Turns out you have to scroll to the bottom of the G5 configuration menu to "RS232 Configuration" and change Output Format to "Altitude" and the Baud Rate to "9600". Works fine and saved me the cost of an altitude encoder.
I wish more experimental guys worked at these companies. It's not the first time I've had to figure out things about their products that they should know, but haven't played around enough to discover.
