I'm doing my annual on my 1998 RV4 with 600 hrs TTAF. I noticed that the fuel selector seemed a little loose in the shaft. I pulled the handle off and checked that the cap was tight and it was. No leaks but just seemed a little wobbly with some slight up and down motion. Never noticed it with the engine running but I do with it sitting in the hanger. The friction to turn it seems normal. I can barely hear/feel the click for the detent but it does make a squeaky sound like its dry.
Is the valve talking to me?
How many pieces in side that could fail? The valve handle uses the small pointy end to point at the tank in use and it has a D shape to it so it only goes on one way.
I'm wondering if this is anything to worry about?
And my tanks are full.....................
Tim
Tim
