rag
I replaced the panel (and firewall forward) on my RV4. I'm learning all the neat things that the Skyview has to offer. One is carb temperature. I have not figured out how to use the info it is providing. It seems to be in the "red" most of the time (32 +- 10 degrees). OAT's in the low 40's. Older posts indicate the carb temperature is of limited value due to the inaccuracy. Wondering if others would have more current info as to if and how they use it to determine carb ice conditions? What is the typical temperature they see as compared to OAT - in cruise and on the ground. Thanks!
