  #41
Old 12-29-2016, 04:55 PM
tracy tracy is offline
On an RV-8 (or A), the designation of -1 means different things for the fuselage and wings.
There are a lot of 8's and 8A's that were built with a -1 wing but not a -1 fuselage.
A -1 wing means it is a wing kit after the date which 7 and 8 wing kits were being delivered with many parts common between them. The wing spars are basically the same, with the only significant difference being in the bolt hole pattern for attachment to the fuselage (so the wing kits are not interchangeable to a 7 or 8 fuselage). because of some minor changes in the wing spar at this point, an RV-8 with -1 wing got a 50 lb increase in approved aerobatic gross weight but the max. gross weight stayed the same.
A -1 fuselage means it is a fully match hole/prepunched fuselage kit (introduced sometime around 2005), vs a non match hole kit where for the most part only the skins were prepunched.
Good to know! Thanks.
Tracy Willingham
RV-8
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 01-04-2017, 12:35 PM
G5Driver G5Driver is offline
Early QB Kit, Rivets in place. No Bolts or holes for bolts.
S/N 81373
RV8, N658RL, 0-360, Hartzell CS, Dynon EFIS, (KCXP)
RV-14 QB #421
Old 01-07-2017, 08:45 AM
chrisi456 chrisi456 is offline
Default Slow build kit
Is there any reason to check a slow build RV-8? Taildragger?
Old 01-07-2017, 09:31 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Not if you built it and you know you put them in. Otherwise, yes, check. Very easy to do with a flashlight and an inspection mirror. Pretty cheap peace of mind.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 01-22-2017, 04:53 AM
Capflyer's Avatar
Capflyer Capflyer is offline
It is silly that they don't install these bolts during the quickbuild process when access is much easier. As noted by many posters, this was overlooked during construction so just think about how many folks out there are not on VAF and will not get the message. Vans has taken on a huge risk by not being proactive and thinking through this easily overlooked construction detail by not having them installed during the quick build construction.
Mike
Based in the DC SFRA where the Forces of Darkness gaze upon our every move
http://www.youtube.com/watch?v=i9rzECL26AI
Current Project - RV8 Hot Rod
Currently Flying - RV8
RV4 - FAST & FUN! 0320 GRT IFR Panel - Sold to another Very Lucky Guy
RV-7A Built, Flown, then Sold to a Very Lucky Guy
Old 01-26-2017, 08:09 AM
gnuse's Avatar
gnuse gnuse is offline
Kit Sn 81074
Rivets in place, so no holes for bolts.
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 02-09-2017, 11:39 AM
agflyboy agflyboy is offline
Builder 80977 looks like no holes just rivets.
I'm not sure why they won't link? Uploaded them to my photobucket account, copied the link, click the insert image icon, paste the link, click ok to embed the image???????????
http://s776.photobucket.com/user/kev.../SL%2016-12-16
Kevin Ebsen
RV-8, N321EB
Flying as of 4/20/2001
Old 02-09-2017, 01:09 PM
Veetail88's Avatar
Pics not showing up.
Jesse Bentley
Old 02-13-2017, 08:36 AM
I think I finally got the link to work.
Kevin Ebsen
RV-8, N321EB
Old 03-07-2017, 06:27 PM
AAflyer's Avatar
AAflyer AAflyer is offline
Default These bolts are too big
Originally Posted by AAflyer View Post
OK...let's REALLY open up a can of worms, and ask for opinions on these puppies!
http://www.peerlessaerospace.com/Pro...MG_VISULOK.pdf
My buddies and I made a group order of these expensive bolts, thinking it was the "smart way to go". They can be installed like blind rivets; you only need access to one side of the material. Seemed too good to be true...and it was. We've discovered,...now that we have the bolts in hand, that they do not fit through the holes! They are about 6/1000 too big.
To ream, or not to ream...that is the question.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2018 Dues Paid
