Aren't you supposed to level the fuselage using the longerons?
Well I figured ultimately I want the wing and horizontal stabilizer to line-up/be in the same plane with each other, so I used the spar carry-through as a reference point. How would you suggest I check for unacceptable twist in the fuselage?
T.
Cleco on the top fuselage skins and that should help get the twist out. It is all prepunched, so it should line up with all of the other holes and make a straight fuselage. Do this before you drill the aft deck and make the twist permanent.
Bruce's recommendation is spot-on. The aft fuselage will not be torsionally stiff until the top skins are attached. Better to chase this twist out early.
Any chance that the rotisserie contributed to this twist? Looks like the CG will be offset from the axis of the rotisserie support, tending to twist the fuselage when it is displaced sideways. Try rolling the fuselage to level from the opposite direction and see if the twist is reversed.
Please share results!
- Roger
Tom, I owe you an apology regarding my comment about making sure the spar is level. I just found/re-read this note on Van's site regarding setting the wing incident angle and it mentions checking spar angle.
That said, great news on your tail section! It is good to hear it turned out fine!
