Old 08-27-2018, 10:09 AM
Black8's Avatar
Black8 Black8 is offline
Default Solo Builder
Is there anyone out there that has built an RV without any help??? I've built an 8 and now i find myself without a "Bucking Buddy"..(my dad helped with my 8).
I would just like to here from someone...anyone that's done a solo build that can tell me how hard they found the build.
Thanks, Joel McMillian S/N 83585
Joel McMillian VAF#1954
Old 08-27-2018, 10:21 AM
jcaplins's Avatar
jcaplins jcaplins is offline
On my slow built rv7, I would estimate I bucked 98% of rivets by myself. I wouldn't say any of it was "hard", just time consuming. When you do need a second person I'm sure it won't be an issue to find some help. I'm not sure it could be done 100% solo unless you start replacing some wing skin solid rivets with pull rivets.
I aligned, drilled, and final installed the wings solo.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 08-27-2018, 10:22 AM
Mark Dickens's Avatar
Joel,
I built mine at least 95%+ by myself. And it took me over 7 years of actual building to finish (17 if you include 10 years of no progress at all). Some things are impossible without help. What I discovered is that having a "building buddy", someone who's also building one, was invaluable to maintain motivation for both of us, not to mention that you help one another with bucking, ideas, etc.
Since you've built an -8, I assume you're looking at another project? I'm sure there are builders in the Birmingham area that would be glad to assist when you need the help. What are you planning to build?
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 08-27-2018, 10:37 AM
bruceh's Avatar
bruceh bruceh is offline
I only needed riveting help with the wing skins (top) and leading edge ribs, some of the center-most rivets on the fuselage, and few other places on the fuselage (forward top skin). I would say 99% can be done solo. Maybe 95% if your arms are short.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 08-27-2018, 10:58 AM
rbibb's Avatar
rbibb rbibb is offline
Not an RV-8 but I built my RV-4 solo and the only rivets I had help bucking were on the top skin of the tailcone.
Long arms help...
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 08-27-2018, 11:22 AM
Default Ditto on my -4
Built my -4 solo as did Richard..only a couple in the upper tail cone. My then 8 year son old bucked them. Biggest challenge was probably the Wing L/E skins reaching up through the spar and rib lightening holes. In my case, I built the majority of my plane late at night when help wasn't around.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 08-27-2018, 11:46 AM
Default Good luck
Not easy. Expect more smilies in hard to reach areas. Have a good stock of correct CherryMax blind rivets. There will be a dozen or two solid rivets you absolutely need a shooter. Catch anybody fit on the street and train.
Old 08-27-2018, 01:29 PM
I'm building solo and long ago decided not to be hesitant about getting help. Fortunately there are plenty of good people in my area who are glad to lend a qualified hand. I try to show a photo of them at least once and mention their names in my VAF build blog.
Old 08-27-2018, 07:35 PM
coffeeguy coffeeguy is offline
I agree with Vlad. Most of my rivet smilies or dings are there because I was reaching, trying to buck and shoot at the same time. Yes, I do have some smilies and dings.
Jeff Dingbaum
RV-14A empennage, wings
Cherokee 180
2018 dues paid
Old 08-27-2018, 07:53 PM
wjb's Avatar
wjb wjb is offline
I agree with the earlier posters that 98% can be done solo. When needed, I've enlisted the help of interested friends (and kids) to shoot the impossible-to-do-alone rivets. I'll train them on some test pieces/scrap so they get the feel (maybe 50 rivets total) and then go at it. Stressing and practicing communication is KEY. How to be sure they're on the same rivet as you, when to shoot, and when not to.
The engine even goes on easily solo with some planning and patience.
... but I sure wish the neighborhood kids took a stronger interest; it would be heaven to have an eager-beaver always wanting to help. (My kids, unfortunately, no joy)
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
