Old 07-07-2018, 06:00 PM
wjb's Avatar
wjb wjb is offline
Default Too tight main axel/bering fit .. hints?
Hi Folks,
I'm attempting to put the wheels on the gear, but find that both main axels are bit oversized and the bearings will not slide on (even with some light encouragement)
Anyone else see this? A leftover from heat treatment of the legs?
Anyone have any magic tricks, or is it grind to fit? No way the bearing's gonna stretch.
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 07-07-2018, 06:17 PM
Vern's Avatar
Vern Vern is offline
Default Axle fix
Get a roll of plumbers sandpaper ( actually a long roll of emery cloth) used to clean copper fittings. Big box stores sell it in about a 2” x 2” box. It is fabric backed and will help you dress the axle so the goodies will slide on the axle. It is about 2” wide by ten feet
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Get some emery cloth or a strip of 600 grit sandpaper. Wrap the paper halfway around the axle and saw it back and forth to slowly sand down the OD. Reposition the paper frequently to keep the axle round..
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-07-2018, 06:25 PM
Larco Larco is offline
Absolutely and I will add that if you remove the bearing from a wheel and sand the axle until the bearing slides on and off, easier than using the wheel?
Old 07-08-2018, 08:12 AM
wjb's Avatar
wjb wjb is offline
Thanks for the tips! Looks like I'll open a cold can of elbow grease at get to it....
Bill Bencze
Old 07-08-2018, 08:47 AM
n4322b n4322b is offline
Originally Posted by Vern View Post
Get a roll of plumbers sandpaper ( actually a long roll of emery cloth) used to clean copper fittings. Big box stores sell it in about a 2 x 2 box. It is fabric backed and will help you dress the axle so the goodies will slide on the axle. It is about 2 wide by ten feet
I'm told the same process is required on the landing gear legs as the enter the sockets and I had to do same on the tailwheel spring too
Fuji FA200 / 160 - sold
Sonex - Aerovee - Sold
RV7 in build
Old 07-08-2018, 01:41 PM
Vern's Avatar
Default Enlarging gear sockets interior
Use the same technique. Some brake cylinder hones with some oil on them allow you to slightly enlarge the gear sockets. You can also use stones in a power drill, or some of the emery paper in a slot cut in the end of a dowel
Vern Darley
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
ATP/CFI/A&P/DAR
Old 07-08-2018, 10:31 PM
wjb's Avatar
wjb wjb is offline
Post op report: The plumber's pipe dressing tape/sandpaper did the trick ... it took about 15 mins a side to remove enough material for the bearings to slide on.
Now, the baby has new shoes! Thanks for the help.
Bill Bencze
