Old 03-04-2018, 08:12 PM
kkmarshall kkmarshall is offline
Default SureFly electronic ignition
Decided to give the new SureFly ignition a try. One thing about it,they have made the install/conversion super easy and painless. Have only made a short test flight so far and not at very high altitude but it does start quicker and I am able to go further LOP. Perhaps 10-15 degrees higher CHT at most. Keeping the right non-impulse mag for now. Time will tell,but so far I am impressed with cost
(1500.00) ease of install,and apparent quality construction.
Keith
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 03-05-2018, 07:35 PM
Steve Barnes Steve Barnes is offline
Talking Happy with mine
I have the 6 cyl version. I can run a lot more leaner. To kill the engine I have to pull the mixture out noticeably further.
Old 03-13-2018, 06:42 AM
Default SureFly thoughts
Have 6 hrs on the new ignition including almost 5 hrs of that being a cross country and have been well pleased. Definitely starts better cold or hot and I am able to lean around 3/4 of a gallon less per hr without roughness. Of course that brings with it a reduction in power output but if you want to save fuel and are not in an all-out hurry you can do so. I didn't notice much CHT increase,perhaps 10-15 degrees at most. My Mattituck was configured with a left impulse mag which Slick does not like at all and recommends a 250 hr inspection of the impulse coupler. So you can eliminate that issue for less cost this way than buying a retard breaker mag and Slick Start. And have a (promised anyway)
no maintenance ignition on one side. I am very impressed by ease of install and timing. Reliability,time will tell.
Keith
Old 03-13-2018, 04:03 PM
Pat Stewart Pat Stewart is offline
Great company with great people.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 03-17-2018, 03:39 AM
supik supik is offline
What AMPs fuse does the Surefly need on the power lead? thx
Igor
RV-10 in progress
Build Log
Old 03-17-2018, 06:28 AM
The unit comes with a length of wire with a 10 amp fuse inline.
Keith
Old 03-19-2018, 03:58 AM
thanks Keith!
Igor
RV-10 in progress
Build Log
Old 04-15-2018, 01:35 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default MAP hook up?
Keith
How did you handle the MAP line? Did you tap a different Cyl. and if so what fittings did you use?
Ivan.
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1210hrs.
Dual GRT 8.4" HXr EFIS, VP-200, TT A/P, Avidyne IFD440, Dual EI's, ADSB in/out.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 04-15-2018, 04:53 PM
I tapped into the unused primer port on #6 as it was closest to the new ignition.
Brass fitting from your local NAPA. Ignition comes with a length of MP hose.
Still quite pleased,definitely starts quicker,hot or cold. Not that it was bad before but just fires off one blade or so sooner.
Keith
Keith
Old 04-15-2018, 05:36 PM
Northernliving Northernliving is offline
Keith, What were the advantages/disadvantages over a PMag? Interested in replacing one of my mags and would appreciate pros/cons of the PMag vs the Surefly.
Brian
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Dream - Under Construction
