Old 02-04-2014, 09:14 PM
knievel knievel is offline
http://www.mcmaster.com/#standard-drill-bits/=qk0hch
No need to kill.
Scroll down to "High Speed Steel Jobber's Drill Bits for Plastic".
Old 02-04-2014, 09:27 PM
JonJay's Avatar
JonJay JonJay is offline
No need to kill.
I have those. Ill have to see how it works.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-05-2014, 04:36 AM
60av8tor 60av8tor is offline
As long as the bit is sharp, turning the bit by hand initially makes the procedure fairly easy and consistent. Turned by hand, a sharp jobber with slight pressure bites and really begins to start a nice hole. After that, as long as I do not get impatient (checking my depth as to not descend past the head or drill off angle) drilling the head off is rather straightforward. As others have said, the bit is steerable back to center if you begin to drift.
Jon
RV-7A purchased flying - Sold 6/16
RV-10 empennage delivered 1/22/14 (325JT)
Build: http://hhav8or.blogspot.com/
Old 02-05-2014, 07:26 AM
glenn654 glenn654 is offline
What has worked best for me is to use a cordless drill to drill the rivet head.
The drill can be started and run very slowly and greatly helps keep the bit centered.
Then after you have a good pilot hole you can speed up the drilling process.
Works for me!
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 02-05-2014, 07:35 AM
PJSeipel PJSeipel is offline
Regardless of the rivet size I always start with a really small drill bit, like 1/16 or smaller. A bit that small will stay centered in the little divot on top of the rivet pretty easily (and if the rivet doesn't have one, I make one with a center-punch). No pressure, just high speed on the drill making sure to keep it perpendicular to the surface. I drill about 1/2 to 3/4 of the way through the rivet head and then up-size to the next drill bit. I'll usually hit each rivet with 2-3 different bits depending on the size. By starting small and going up in increments it's much easier to adjust if your hole gets off-center. Starting small and moving up also makes it easier to keep from drilling all the way through the rivet since you can feel when the bit hits the end of the hole you've already drilled. Since I started doing it this way I've yet to mess one up.
PJ Seipel
RV-10 #40032
Old 02-05-2014, 08:53 AM
pa38112 pa38112 is offline
If you do happen to drill a hole off center you can walk the bit back to center (the machinist term is “draw” it to center) as long as you catch it before you have reached the full diameter of the bit. You do this by putting a small mar on the edge of the hole with a cold chisel. The bit will walk towards the mar. You can move the bit over a little at a time. I suggest practicing on scrap to master the technique before trying it on your plane.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 02-08-2014, 03:10 PM
Default Minimizing hole damage while removing rivets
Not wanting to hijack Walts thread, but since it seems he was opening discussions on processes to use, I thought I would add a detailed explanation on how I do it. I hope some of you find it useful....
Regardless of how experienced a person is, it is nearly impossible for them to remove rivets by drilling down the length of the shank with a net size drill bit. Even a slightly smaller bit (3/32 instead of #40) will do little to help with the level of success.
The following is a process I have used for many years. Though I have very little experience with anything larger than 3/16, with slight variation it should work for everything from 3/32 rivets on up to what ever size you are dealing with.
1. Center punch the rivet head. If it is an AD rivet , use the identifier dimple in the head center otherwise eyeball where the center is.
2. Use a drill bit sized the same as the hole you are removing the rivet from, to drill into the rivet head just deep enough that the full diam. of the drill bit is at a depth approx. the same as the thickness of the manufactured head of the rivet (the point of the drill will be just slightly below the material surface of the underlying part/skin). I use a cordless drill running at slow speed. This gives me time to drift the hole back to center before the full diam of the drill point penetrates the rivet head. Some people prefer to start with a smaller diam. drill. This does help it stay centered in the previously made center punch, but for me it is far easier to tell by eye if the bit is staying centered, if the drill bit is closer to the actual diam. of the manufactured head of the rivet. Experiment and see what works best for you.
When in a situation where an angle drill must be used, I make a little wood spacer for the throttle lever and tape it to the handle so that it prevents the lever from being depressed all the way. You can then set the drill speed using the pressure reg. for the air line, and have it run at a consistent speed every time (this seems to work more consistently than turning the pressure way down low and opening the throttle all the way)
3. Use a drift punch or the blunt end of a drill bit that closely matches the hole diam., and pop the rivet head off… insert the punch and tilt it over to the side to snap the head off. If it doesn't immediately pop off, try prying in multiple directions… you may have been (hopefully) just a little bit off center with your drilling.
The reason for this next step is to relieve the expansion of longer rivets within holes, and give the rivet a space to collapse in on it self as it is being pulled or driven out.
If you were to look at a cross section view of most rivet holes, it is far from being a smooth bore. There are minute little relief areas because of the small chamfers that occur on the hole edges while deburring. If one or more dimples are involved, then there is even more void areas. When the rivet was originally set, the rivet shank swelled into all of these areas to some degree. That makes it grab and resist being pushed/pulled out of the hole.
4. Once the rivet manufactured heads are removed, change to using a drill bit one rivet hole size smaller than the hole you are working with (1/16” for #40 hole, #40 for #30 hole, etc.). The goal in this step is to drill down the center of the rivet shank, but stop short of drilling through the shop head on the other end. The ideal stopping point is about ˝ the rivet diameter before entering the shop head. On longer rivets, you can wrap some tape around the drill bit to use as a depth stop.
In cases where a short rivet (usually 3/32) is used to attach a skin to a rib, etc., you can usually skip this step, as the rivet is small enough it will still shrink and pull out easily without drilling a relief hole (using the rotating removal process described in the next step)..
The goal of the next step is to utilize the relief hole we drilled previously, to cause the rivet to stretch in length. If it will stretch in length, it will slightly shrink in diam. This will help get the rivet to let go of all of the small void areas within the rivet bore, and reduce the friction inside the smooth part of the bore allowing it to slide out much more easily.
5. This can be done two different ways.
The first is what works best with rivets 1/8 “ and larger, but particularly larger than 1/8”.
Insert a pin punch in the relief hole and drive with a hammer. Depending on the structure you are working on, you may need to also back up the material around the shop head to avoid distortion, but since you are driving at the bottom of the relief hole, the rivet should begin to shrink in diam. with the very first hit, and drive out relatively easily.
The second way to shrink the rivet diam is by rotating it. I have a rivet removal tool made of a long handle side cutters similar to THESE. They have the smooth face (facing you in the photo) ground down slightly, and polished smooth so that the sharp portion of the cutter can get very close to the surface of a flange or skin to grab a rivet shop head. Note, they must be a long handle variety to provide enough leverage to grab the rivets tightly enough.
I grab a rivet shop head with the tool, squeeze hard, and wiggle the tool back and forth quickly, trying to rotate the rivet. Once you can get it to move about 10 deg., you can usually tilt the tool (while still squeezing hard) and pry the rivet out of the hole. This has low risk of causing any distortion to the parts (if you were able to get the rivet to break free and rotate) and it can be done with one hand… you don’t have to hold a hammer and punch, and then somehow also hold something to back up the material for the force of the hammering.
The added benefit is that you can use the process in areas where it is not possible get a punch and hammer onto the rivet. A perfect example being the rivets within the two skin bays of the horizontal stab., that attach the top and bottom angles to the spar webs, that need to be removed to install the spar doubler for the S.B. If the relief hole is drilled deep enough, even though the material stackup thickness is .157” the rivet will easily collapse and pull out using the side cutter tool.
Extra tips…
When working in difficult areas, particularly where you might be using an angle drill where determining drill alignment is difficult, start with a hole that you can install a cleco in after rivet removal and still have access to the rivet(s) adjacent to it. The cleco can then be used as a visual guide to determine if the drill bit is square to the surface.
Try and avoid drilling through the shop head when drilling the relief hole. It removes the ability to drive with a punch in the bottom of the hole (obvious) and it increase the possibility that the shop head will break off the end of the rivet before you can get it rotated or pulled/pried out.
Short 3/32 rivets (ones that attach skins, etc.) remove very easily using the rotate / pry out method. I use this process exclusively when removing skins, etc. When the only drilling done, is just what is required to get the manufactured heads removed, there is very low risk of damaging the holes.
Scott McDaniels
Hubbard, Oregon
Old 02-08-2014, 03:46 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Great write-up Scott - check your PM's!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-12-2014, 03:29 AM
Hum's Avatar
Hum Hum is offline
Default Thanks!
Great advice here, thanks to all for taking the time to share your knowledge & wisdom :-)
Old 02-12-2014, 01:51 PM
rapid_ascent rapid_ascent is offline
One thing that I've found that seems to help and I must admit I'm not an expert, is to use my lower pressure line to run the drill. The drill has less torque and is easier to control. It does of course drill slower too.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
