Auburntsts
So if you have been following the MT prop gov saga, you are most likely aware that we established that the Hartzell gov for the 540 comes in two flavors:
S-1-26 for narrow decks
S-1-32 for wide decks
We also had established, or I thought we had, that Van's carried both but under the un-intuitive nomenclature in the catalog of O-540 and IO-540 (I say un-intuitive because the fuel delivery system has no bearing on the correct type of gov for a given engine). Any way, thus informed, I ordered the O-540 version under the impression I would get the S-1-26 narrow deck model.
Nope. The box had O-540 written on the outside but also a printed sticker that said S-1-32. My heart sank. I opened the box all the way up to verify ad sure enough it's an S-1-32 wide deck model. So I get to call Van's tomorrow and see what I need to do to return it. I guess I'll also see if they have any S-1-26s still sitting on the shelf. ARGGGHHHHHH.
EDIT: Heard back from Van's -- they do not carry the S-1-26 model. So if you are in search of a prop gov for a narrow deck, you'll have to look elsewhere.
