oil/fuel pressure senders
Deweyclawson
I am installing the GRT EFIS and eng monitor systems in my new (to me) RV6A.
Does anyone have a source for fittings to mount the oil press and fuel press senders to. They are the same senders I have seen on Dynon and MGL installations. The threads on the senders measure 27tpi.
The threads on my GRT sending units were 1/8" p.t. Does your RV6 have the sensor "manifold" that's now standard to RVs?
This is the standard Van's piece, set up to accept three senders, but I cut off the top one as I only need oil pressure and fuel pressure.
senders mount
Thanks guys.
I had only one cylinder with egt/cht so no sensor mount. No sensors. Direct reading gauge with oil and fuel lines to the back of the inst. panel. Plane was built in '93. I just ordered the mount. that is exactly the thing.
