Wunderon
Hi,
I wanted to use the induction tubes (IO-360-M1B) to support my starter motor and alternator wires, with big adel clamps. The tubes seem plenty solid for this application, but I wondered about affecting the pressed-in seals at the sump with the extra strain, inviting a leak.
For the sump routes, I've got a governor oil line in the way on the right and fuel line + mixture cable in the way on the left.
Are induction tubes ok for big wire support?
Thanks so much
Thanks so much
