Engine pics from PennYanAero build
bkthomps
decided to be different and go for a white engine with contrasting accessories (it's actually a white metallic flake), ECI cold air induction pipes will be polished and should give an interesting contrast
That's a great color to spots any leaks and will keep the area bright during visual inspections. Nice!:)
They're both excellent points. It's amazing that this isn't standard!
- mark
that was part of my goal, Bill @ Penn Yan Aero said "don't worry about that, my engines don't leak"
Rest assured when I spill oil filling it up, the cowl is coming off and I'll be cleaning it up!
Here's more pics:
- mark
Newt,
Good points, yes, but it's also a great color for collecting dirt and grime.
No offense intended Brian. It's a nice color, but I think you'll spend almost as much time trying to keep it clean as you will flying it.
Newt,
none taken, that is right in keeping with my personality- I will keep it clean :D
Penn yan is going to use it for a magazine ad photoshoot, I'll post up a pic when they send some pro shots
The clear yellowed a bit on the cylinder heads, but we are going to fix that with another coat of white/clear mix for the cylinders.
Made 184HP and is expected to make a bit more once it is all settled in and the rings are seated better.
Brian,
Nice HP output! Good to know it won't be a slug... ;)
Do you think the yellowing on the heads (obviously caused by the combustion heat) will be a persistent problem?
Brian,
we will see, not a huge deal if it is but I am hopeful a top coat will solve that.
it's a good day indeed!
keep pounding those rivets (or in this case, saving those pennies)
