Old 10-02-2013, 12:19 PM
Bob Axsom Bob Axsom is offline
Default The Crankshaft front plug
I received a message that told me the front plug in the crackshaft is to be removed with this new adapter cover plate. Any thoughts on that? I'm struggling to see how that can work.
Bob Axsom
Old 10-02-2013, 01:45 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Sounds like an excellent way to keep the whole front of the plane well lubed and corrosion-protected... for a short while anyway.
Methinks the correct solution is to have both crank plugs in place with the oil line in place and the special slotted cover plate over the back of the governor drive adapter. The normal oiling of the front crank bearing via the crankcase oil galleries and the oil crossover tube inside the hollow portion of the crank will still fill the hollow end with oil at somewhere near the engine's oil pressure, and it needs to drain back thru the line and into the governor drive adapter and then back down into the sump via the slotted cover plate. At least that's my understanding of how it all works.
Neal Howard
Airplaneless once again...
Old 10-02-2013, 02:05 PM
jrs14855 jrs14855 is offline
Default Plugs
For fixed pitch prop-front plug in place-hole in rear plug OR solid rear plug with governor line returning oil to governor pad cover. The external line with solid rear plug allows switching back and forth between fixed pitch and constant speed with much less work.
For constant speed- solid rear plug NO front plug.
Old 10-02-2013, 02:10 PM
Default That was my conclusion as well
The source is highly respected so I tried to mentally make it work. I must have misinterpreted the input - my fault in word mismanagement I'm sure - thanks for the reality nudge. I'm sure in retrospect the intent was "you have to take the forward plug out to go back to C/S operation" - I need more sleep. I have the special cover and forward plug on order.
Bob Axsom
Old 10-11-2018, 06:22 PM
kthom_441 kthom_441 is offline
Default Engine Conversion
So it's been about 5 years since this thread was active. Since then someone must have tried it and can report their success (or not). I have my engine installed, O-320D1A, setup for CS operation and plan to use a FP. I like having the ability to convert back someday without major surgery.
So does this work? What is the part number for this special cover?
As an alternate, if I were to follow the Lycoming SB and pierce the rear plug, what can I expect to invest time-wise? I'm certain that removing the engine will be a first step.
Thanks to all!
Ken
RV-9A (Yep it's got that wheel in front to lead the way)
Old 10-11-2018, 06:50 PM
rhill rhill is offline
Default CS to FP and back again
Post a picture of what you have. If you have the adapter and the steel line in place, your good to go. The S.S. Line is expensive. Its a little added weight in trade for the easy conversion to CS later on. Piercing the inner plate and replacing the outer cover is fought with issues if the cross over oil tube is damaged in any way.
Old 10-15-2018, 06:25 PM
Default Set up for CS
Not able to get a picture easily. My engine is all set up for CS operation. I have the SS line from the front to rear and the governor port is covered with the plate that seems to have the notch in it. Best I can tell, I only need to put the front plug in and I'm all set to go with FP. My concern to validate this method since neither Lycoming nor VANs says anything about going this route. Are there any on here that have done this and have had no long term issues?
Thanks for your comments.
Old 10-15-2018, 10:23 PM
Best of both worlds. Check to make sure the rear cover plate is the pressure relief style,install the front plug. You should be good to go FP. When you have an extra $10K you can add a CS prop.
Old 10-15-2018, 11:28 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
The Lycoming documents allow for a flex hose made to a specific TSO specification.
https://www.lycoming.com/sites/defau...ce%20Versa.pdf
I was lucky and found a used SS line here on VAF.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-22-2018, 07:04 PM
Default My decision
I've exchanged emails with Lycoming and they wouldn't even discuss any alternative conversions beyond their Service Instruction. I also had a great conversation with Mahlon a few days ago ( THANKS!) and he gave me a very detailed and complete understanding of the oil flow and the conversion process. Key here is that if I ever decide to change back to CS, replacing that inner plug is difficult without pulling the crank. Lycoming will likely never endorse any alternative mods since they can't analyze all possibilities.
I am in the process of creating my own Work Instruction to document what I am doing now and what steps I would need to follow to convert back to a CS prop. A note to those who have asked about a part number for the rear cover plate with the milled oil channel, mine was supplied by Lycoming with the original engine.
Ken
RV-9A
Caledonia, MI
