Old 09-25-2018, 03:01 AM
Discus2b Discus2b is offline
Well donít that beat all....
H
Old 09-25-2018, 02:33 PM
springer springer is offline
Default More Switches?
I think I need more switches...
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 09-25-2018, 05:32 PM
Quick! What is Vso/fe?
The 8 guys are way more humorous than the 14 guys. I screwed up.
ut oh ... 8 lurker
H
Old 10-09-2018, 10:03 AM
j-red j-red is offline
Finally got to put the driver to the screws this morning and officially install my panel. Had been waiting for the engine monitoring wire harness to be completed and now all the back-panel wiring is done and secured! (cable on the left side is a LAN cable that connects the VPX to a laptop for programming. It stays attached and stows underneath when not in use).
SDS iginition CPi swings down on the right if needed. Not completely invisible when in the 'UP' position, but certainly not an eyesore either. Once all the programming is done, I'll tie its wire bundle up more out of the way.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 10-10-2018, 06:48 PM
XPPilot XPPilot is offline
Default Panel finishing
Looks great! What material did you use for panel finishing?
Old 10-11-2018, 07:32 AM
Itís 3M 1080 series carbon fiber wrap. Pretty thick stuff with a realistic texture to it. I used the additional adhesive over the entire panel and really like how well it stuck and trimmed. It didnít get twisted and turn by the screws which was a concern I had. Itís a little pricy, but the 3í,4í sheet I bought could probably do the whole thing all over again if it gets messed up at some point in the future.
Rebuilt RV-6A N94CR
Old 10-11-2018, 07:40 AM
olyolson's Avatar
olyolson olyolson is offline
Default Carbon panel
Jon,
Starting to remove the center panel on my -8 to do a carbon fiber layup. Was going to send to Stein to have them use real carbon fiber ($$$). When I did the carbon fiber tape wrap on the RV-4 panel I had trouble with the screws puckering the tape. Took some time to get it all straightened out. I was using the 3M Dinoc wrap but I got a roll of the 1080 tape this time.
So you didn't have any issues with the screws puckering the tape at all? Did you do something special or let the tape sit on the panel for a while? Does it harden a bit if you leave it for a while?
RV-8, Flying
Previous airplanes: RV-4, RV-3, Cessna 140, Corby Starlet, Citabria
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 11-25-2018, 02:03 PM
Capt Capt is offline
I'm not a fan of glass (it's my day job) am old school, 40 years driving planes I still enjoy the good old days I would add a panel pix but can't get it to stick -
