Old 04-16-2018, 01:34 PM
titanhank's Avatar
titanhank titanhank is offline
I did it all myself with a band saw, dremel and a file. The panel part itself took about 30 hrs. The entire project, repanel, rewire whole plane, install autopilot, convert to electric flaps and trims, install pmags, rebuild both wheel pants, rebuild both brake calipers, and program everything took 2 months and about 150 hrs. It was definitely worth it. I would never go back to manual flaps and trims.
Rv-6
0-320/190+hp
10-1 pistons
Lycon port/polish
Dual pmags
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
Old 01-10-2019, 11:39 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
Location: Zürich W, Switzerland, Europe, Earth, Milky Way, known Universe...
ok, here we go: my minimal VFR day only panel... light, simple, and functional
Since I bought the -6 already built, I didn't design the panel. The holes were already there, and I've just spent about 14 days rewiring the headsets, installing a new 8.33KHz COM, a Garmin G5, a GT-50, and a Garrecht AT-1 TAS.
Not shown on the foto, the iPad mini which is affixed by the ball.
Retired from the airlines I prefer to enjoy the outside scenery instead of perusing an acre of glass with zillions of useless stuff on it. And no A/P either
Life's short... Enjoy!
DC
http://www.aerofun.ch
RV-4 HB-YVZ airframe builder
RV-6.5 slider HB-YLL owner
Old 01-11-2019, 03:57 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Hello DC
Nice and a good decision to look most of the time outside, as a VFR pilot!
Can you give a bit more info about the AT-1 TAS? Could not find more info.
Thanks!
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 01-11-2019, 04:24 AM
Raiz Raiz is offline
It looks like one of these https://www.air-avionics.com/?page_id=253. Garrecht products are now sold under the Air Avionics brand.
Old 01-11-2019, 09:31 AM
DeeCee 57's Avatar
Raiz is correct. I had a TRX-2000 installed in my previous craft and was very happy with it. The AT-1 is the successor to the TRX-2000 and the TRX-1500.
And for the non-European reader, all these devices are Traffic Avoidance Systems. They will detect all traffic emitting thru standard transponder equipment, modes A/C/S, ADS-B, and FLARM. They also issue conflicting alerts, albeit no avoidance instructions (TAs but no RAs).
The downside is that installation in a metal aircraft such as the RV requires additional external antennas: 1x ADS-B, 1x FLARM on the top of the aircraft and 1x FLARM on the bottom. The GPS was kept internal and stuck to the glareshield.
DC
Old 02-13-2019, 04:28 PM
DeltaRomeo's Avatar
Your host.
Default Panel pic and neat RV-6 center console seen at Monk's.
Neat RV-6 Center Console Seen at Monk's.
In for P-mag install. Note the aileron and elevator trims. Very creative!
Even higher res images at:
https://dougreeves.smugmug.com/Planes/N63PM/
v/r,dr
doug reeves.
- Biz card: www.DeltaRomeo.com
Organ donor card signed (use anything you need).
RV-6 flying since '02.
- Commercial Rating (2019 - in the RV!)
- IFR Rating (2015 - in the RV!)
Old 03-13-2019, 02:19 PM
flyr747's Avatar
flyr747 flyr747 is offline
Smile Panel Upgrade Complete: Old vs New
Dual 10" Dynon HDX with all the Dynon supporting cast plus Vertical Power VPX Pro.
Thank you to Dynon for the Great Support.
Curt & Terri Sullivant
Longwood, FL KSFB
RV-6 N6CT
Old 03-13-2019, 09:03 PM
dreed dreed is offline
Wow! Looks great. How do you like the Dynon's so far?
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
IO-390 hanging now
Hartzell Composite prop taking up valuable shop space
2018 and 2019 VAF dues paid
Old 03-14-2019, 05:05 AM
flyr747's Avatar
Still exploring the depth of its capabilities. Seems very intuitive and straightforward in use. I do think it would be nice to see a more in-depth pilot manual and / or an online simulation or training device allowing pilots the chance to explore options and develop procedures on the ground then applying that when airborne.
Overall I’m very impressed with the way and how much information is presented to the pilot vs the cost. Looking forward to flying it more and exploring further.
Longwood, FL KSFB
RV-6 N6CT
