Old 09-24-2018, 11:54 AM
John Owen John Owen is offline
Originally Posted by Ironflight View Post
Strikes were all the rage for the RV-8 before folks figured out that good intersection fairings did the same thing and with lower drag - that was more than about a dozen years ago. So if you like them and are happy, thatís fine....but for folks building today, make (or install) intersection fairings and you can forgo the little things....
I looked on the Van's website and couldn't find anything about intersection fairings. Do you have a source for them?
John
Old 09-24-2018, 12:03 PM
John
I did a search with Google and found fairings, etc. I will need to look to see how they are different than the ones on my -8.
Old 09-24-2018, 12:17 PM
Mark Dickens's Avatar
I used the RV Bits fairings and have no bad behavior at all. This is interesting to me because when I went down to Houston for transition training with Bruce Bohannon, he had strakes on his RV-8 and swore that they mitigated some sort of airflow disruption when he was close to stall causing a slight momentary "swerve" (best word I can come up with at the moment). I never noticed it probably because my own bad technique was worse than the "swerve". Randy Lervold also wrote about this on his site and Mike Robbins put some on his plane as I recall.
All I know is that my plane is extremely docile on the stall with no weird behavior at all. I can sit there power off with the stick in my gut and it just bobs up and down as I lose 1000 fpm.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 04-06-2019, 03:23 PM
Saville's Avatar
Saville Saville is offline
Default Landing with PAX
Well I got a nice reminder today that having a pax of substantial weight (i.e. an adult not a kid) can have an effect on landing.....
1st landing - bounce go around
2nd bounce bounce bounce go around
3rd greaser
4th greaser
5th a bounce but not too bad and a landing.
All safe....but really really ugly
Need more practice with an adult in the back seat
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 04-06-2019, 05:26 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Add a little throttle when you get down on the deck. I had a 230 pounder in the back today after not carrying a pax for a while. I was extra cautious to add a touch of smash and it worked out real well.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 04-06-2019, 05:44 PM
Saville's Avatar
Yeah that's how I got the greasers. added a bit of power.
Flying RV-8 N880BC
Old 04-07-2019, 12:17 AM
Capt Capt is online now
My secret to Ldg my conventional u/c 8 when a pax is in the back, well anytime actually, I trim nose heavy, slightly, that way when I flare and touch down all I do is release some of that back stick position and it nails the landing👍 two things that puts a plane back into the air after touchdown, ROD (high excess energy) and AoA, reduce both reduce Newtons Third Law
Old 04-07-2019, 11:07 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
You don't have anything additional installed on your wings? Mine shakes before stalling so I recover then. Never have let it go into full stall, might have to try that in a few days when the weather gets better to see if it does like yours.
RV-8 N52VM : Dynon D-180, GTX327, SL40, Garmin 496 GPS, AP74 Autopilot, Titan 0-360A1A2N, Nickel Coated Cylinders, 2 Slick mags (both impulse coupled), engine preheater, Hartzell Plane-Power alternator, Hartzell HC-C2YR-1BFP constant speed, blended airfoil
Exempt by 3 out of the 10 ways but I still donated.
