Old 10-11-2018, 08:37 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Return to Phase 1 time frame/process
Not including engine or prop changes (which are in a different category paperwork wise), what is the actual process for coordinating with the FSDO per op lims for a less but still “major change” like adding an autopilot? Is it simply a matter of getting verbal/phone approval with the FSDO (including test area) or will they require a form of some sort, and then perhaps have to approve it in written form as well? Put another way, is this something that can be done with a quick phone call in the morning and expect to be test flying as soon as I hang up the phone?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2020
Old 10-11-2018, 08:50 PM
Mel's Avatar
Mel Mel is offline
Thanks.
It depends on your operating limitations. Some simply require that you "notify the FSDO of your test area", and some require "approval in writing".
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-11-2018, 08:58 PM
Thanks Mel. My op lims say I must “notify” and “obtain concurrence” from FSDO “as to the suitability of the proposed test area.” Doesn’t say whether it has to be written.
Steve M.
Ellensburg WA
Old 10-11-2018, 09:00 PM
rolivi's Avatar
rolivi rolivi is offline
Is an Auto-pilot addition/or change a Major Modification?
I'm asking Mel more than the OP.
I changed mine out during a bunch of stuff that was Major (read: Catto Prop) but it was just opportunistic. I knew I was going to fly off some Phase 1 either way.
Rob
RV-6A (Purchased)
2019 Dues Paid, of course
Old 10-11-2018, 09:05 PM
Mel's Avatar
Mel Mel is offline
Yes, installing an autopilot modifies your control system and can affect the flight characteristics of the aircraft.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-11-2018, 09:06 PM
rdrcrmatt rdrcrmatt is offline
Along these lines.
We're replacing our IO-540-C4B5 with a IO-540 Thunderbolt.
And I added a yaw damper to our existing garmin system.
Should I go back to phase 1, or at least ask our FSDO if I should?
Matt
CFI / RV-10
Old 10-11-2018, 10:12 PM
Thanks.
Back to the original question... I’m interested in how quick the approval process was for those who went back into phase 1 and who have similar operating limitations as I. Am I likely to get away with just a quick phone call?
Thanks.
Steve M.
Ellensburg WA
Old 10-11-2018, 10:20 PM
IIRC, I had to fax my request, with proposed test area. Response was quick,; maybe a day or two at most.
