Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 10-11-2018, 04:11 PM
Speedbird1 Speedbird1 is offline
Default Fuel Capacitance plates / Dynon issue ??
Hello -
I have an issue with incorrect fuel tank readings. Issue resolved by re-calibration.
Old 10-11-2018, 04:28 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
I have your same set up for six years. I have found that a poor electrical connection at the tank to converter will give me a false reading, sometimes even an empty tank reading. The connection plug that passes thru the tank can leak a drop of fuel over time making this poor connection. For me it has only been on one wing tank and a spray of cleaner will clean it up and restore the gaugeís readings. Now just part of the yearly service list.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 10-12-2018, 08:29 AM
Thanks for the information.
Old 10-12-2018, 09:43 AM
Raymo's Avatar
Raymo Raymo is offline
Your experience is normal. The changes between pours is small but measurable and goes out many decimal places, which cannot be seen in the calibration screen.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 10-12-2018, 11:47 AM
Originally Posted by Speedbird1 View Post
Thanks for the information. Is there any chance you can post your voltage readings for the levels? Mine are SO close together and I was wondering if yours are any different.
https://www.dropbox.com/s/hjtfmaanau..._7673.JPG?dl=0
Sure, Iíll snap a pic tonight, but Ray is right...
Old 10-12-2018, 01:29 PM
Are both you guys getting accurate reading from the tanks? If we put 42 gallons in and burn 21, the fuel flow transducer is right on the money but the tank gauges will, for example say that there are 5 gallons left in the left tank and 7 in the right. Mis-match is a big delta.
Old 10-12-2018, 03:51 PM
smithflys23 smithflys23 is offline
I have your exact issue as well. I think I am going to have to do another calibration.
Old 10-12-2018, 05:04 PM
Aluminum Aluminum is offline
This is not normal. On my setup I had to install a cap in series with the tank plates to bring the swing into the 0-5V output range of the Dynon converter. My plates are bigger than Van's though.
I suggest measuring the capacitance and resistance across the tank plates with a nice instrument to get a quantitative idea what's going on. There might be a short. Epsilon of gasoline is 2, so if your converter barely registers doubling of capacitance something is wrong.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2019 dues worth every penny
Old 10-12-2018, 10:30 PM
I did recalibrate after flying about 30 hours. Now I am within a gallon or two almost all times.
My dipstick is the most accurate, then my fuel flow red cube then my gauges, but close as a gallon or two.
Old 10-13-2018, 06:26 AM
Thanks for posting this. I appreciate it.
