Old 10-11-2018, 02:06 AM
jcboon jcboon is offline
Default attaching the flap motor
There is quite some play where the flap motor is attached to the F-01243B. Is that intentional, or should I insert a few washers and/or thighten the castle nut over "hand tight"? Before inserting the cotter pin?
On the aft side of the flap motor (connecting to the falp crank) it looks fine and tight, but with the two washers on the outside you cannot insert the cotter pin. Is hand tight enough?
Thanks for any help.
Jeroen
Amsterdam
RV-12iS, emp, fus, 2 wings, working on the fin. kit
Old 10-11-2018, 10:04 AM
Wow, electric flaps now! My early gen RV-12 with a D-180 is getting to be a dinosaur!
Old 10-11-2018, 10:17 AM
rcarsey rcarsey is offline
You will never need to worry about the johnson bar malfunctioning!
Old 10-11-2018, 09:12 PM
OMG! Iím repeating myself!😜
Old 10-12-2018, 08:18 AM
NTex NTex is offline
Good morning-
Can you move one (or both) of the washers inside the flap brackets? Then there should be room on the threads to expose the hole on the castle nut for the cotter pin.
It has to rotate so cranking it down tight wouldnt work. You could also substitute a thinner washer.
RV-9A wiring/finishing in progress
Old 10-12-2018, 09:34 AM
Thanks for your help. I put two L washers on the inside (up front) and a fat one on the outside under the nut.
Aft only one L washer on the outside under the nut. I hope this "modification" is OK with Van's.
Jeroen
Amsterdam
Old 10-18-2018, 09:52 PM
rolick22's Avatar
rolick22 rolick22 is offline
I was looking a my clearance between the two F-01243B and the flap motor there is no gap on my parts. I don't have an explanation as to why your gap is larger then it should be. I would have a look at your brackets maybe they where manufactured incorrectly.
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished (need to add the panel cut out)
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
iS Engine Kit in work
iS Avionics Kit ordered
1st GEN FUSELAGE SOLD
Serial#12-0864
N112DR Reserved
VAF donation made for 2019
Old 11-10-2018, 10:20 AM
Thanks for your help and suggestions. I was working on the canopy and didn't look back yet. But I will and try to figure out why this is different.
Jeroen
Amsterdam
