Old 10-10-2018, 10:41 AM
backcountry backcountry is offline
Default Rotax upgrade to fuel injection
Sometime back I heard thereís a company that supplies a fuel injection kit for existing Rotax carburetor engines. Iím not a fan of carburetors and especially dual ones - floats, balancing, dual controls, etc. itís kinda like having two engine tied to the same crankshaft.
Has anyone modified the carburetor engine to fuel injection on the RV-12?
Iím cautious but interested if itís ever proved to be successful.
Old 10-10-2018, 11:40 AM
There is more to it than just changing carbs to FI---
Tom
Ridgeland, SC
Old 10-10-2018, 11:50 AM
Mark33 Mark33 is offline
Edge Performance offers an EFII system. It’s very similar to the current EFI/EFII systems that are currently being offered for our Lycoming based engines. After I’m finished building my current RV-7 project I’m planning on building a Rans S-7 backcountry/STOL airplane and it’ll definitely have an Edge Performance turbo/EFII. Like Tom said though, it’s more to it than than just changing to fuel injection....there’s also some plumbing involved which includes return lines. I’m not sure if the 12 has a header tank or not but if it does, it may simplify the plumbing a little bit.
https://www.edgeperformance.no
Old 10-10-2018, 11:59 AM
Mike S Mike S is online now
VAF member and advertiser http://sdsefi.com/rotax.htm
Old 10-10-2018, 12:01 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
We've been offering EFI systems for 912s for over 10 years and used to supply Edge with ECUs and other bits until they started to copy our parts without permission.
http://www.sdsefi.com/rotax.htm
You will need a return line to the tank and you'd have to check cowling clearance for the manifold and injectors. The manifold may interfere with other accessories We've done installations on several other airframes but never done an RV12 before. We would be interested in working with people who'd like to ditch the carbs. We have a couple of different manifold designs we could offer.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 431.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 10-10-2018, 03:15 PM
We've worked with Ross on several things. Very nice products. But---as i said, there is more to it than removing the carbs and putting an injector rail in place.
Tom
Ridgeland, SC
Old 10-10-2018, 03:33 PM
rv6ejguy's Avatar
If there's some reasonable interest in an EFI conversion for RV-12s we'd be willing to produce custom parts to make a standard installation easier for everyone- the same as we've done for Lycoming, Continental, Jabiru, Rotax and several popular auto conversions for many years.
I don't see any show stoppers putting EFI on a -12.
We'd want to find the best location for the fuel pumps, fuel pressure regulator, have a solution for the return line, throttle cable brackets and develop an intake manifold which clears everything we need to clear.
Old 10-10-2018, 04:39 PM
Excellent points Ross, which I was attempting to to across to Larry. Plumbing, wiring, ECU's, pumps, filters, etc all have to be planned and locations thought out. Similar to changing from a RV12 to a RV12IS---lots of differences!
Tom
Ridgeland, SC
Old 10-10-2018, 04:56 PM
rv6ejguy's Avatar
Tom
Yes and the best way to do all this is to standardize so it works the same for everyone and we can write better documentation for the install.
Old 10-10-2018, 05:17 PM
What would an EFI system cost for 912ULS conversion? Might as well start there to gage interest...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 419
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
