Old 10-09-2018, 10:02 PM
Taltruda Taltruda is offline
Default Pneumatic squeezer pedal question
I want a foot pedal for my pneumatic squeezer.. does anybody know if this would work?
https://www.amazon.com/Interstate-Pn.../dp/B00IKJM2G8
Then if it does, do I connect it inline with the air and adjust the thumb valve wide open?
Tom
Las Vegas
RV-8 empenage started
Baby Lakes flying
Old 10-10-2018, 02:33 AM
Ender Ender is offline
The one I have is from Cleaveland Tools.
Essentially one line hooks up to your normal air source, the other to your squeezer. Then you take a rubberband to hold the trigger on your squeezer closed.
It works really slick for pieces that you can rivet while sitting down (the first part of assemblies and such). I've also clamped the squeezer down to the table, facing "up" so I could have both hands on the piece. This is great for dimpling structure (ribs and other parts it's tough to get the DRDT2 into) as usually I can hold the piece with both hands and move it around.
But once the piece gets large enough you end up being on your feet moving around.
Make sure that you can feather this pedal like you would the trigger. If this amazon one (a bit inexpensive compared to the cleaveland one) doesn't let you feather you'll get into trouble.
Building RV-14A
Flight Test Engineer
www.hikebikefly.com
Dues paid December 2018
Old 10-10-2018, 04:48 PM
PipeDreamer PipeDreamer is offline
numatx-tools.com/numatx-pa-cvs-5272-fp-numatx-parts.html
The part you are looking for is CVS-5272-FP
The cheapest source is Automation Direct (29$)
Alex Babiy
Georgetown Ontario
RV-7A In progress.
Old 10-10-2018, 06:06 PM
tswanson tswanson is offline
Just don't get this one. I bought it and at least the one I got has a lot of hysteresis in it which makes feathering/modulating it difficult enough that I rarely use it.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Todd Swanson
Tremont, IL
RV-7 Empennage in progress
Old 10-11-2018, 10:41 PM
Draker's Avatar
Draker Draker is offline
Huh... I have that exact one and had no problems with it. Works fine and reliable.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 1/2/2019
RV-7A: Empennage and wing kits complete minus fiberglass, fuselage in progress!
Old 10-12-2018, 03:43 AM
RV10Man RV10Man is offline
I built my own. I used an electric foot switch and solenoid, and built a cradle for the squeezer to lay in.
Old 10-12-2018, 07:17 AM
Default Electric
Yeah but can you feather it or is it full on, full off?
Tom
Las Vegas
Baby Lakes flying
Old 10-12-2018, 07:18 AM
Default Feather?
Can you feather it and go slow without it slamming closed?
Tom
Las Vegas
Baby Lakes flying
Old 10-12-2018, 08:51 AM
Naw, it's on or off. I just built it to dimple stuff.
Old 10-12-2018, 04:07 PM
RichF RichF is offline
Default pneumatic squeezer pedal
Went with an Ingersoll Rand model E252FS pedal on a tandem Sioux squeezer and have been very happy with it. I'm sure the model from Cleaveland tool would work fine also. Spend some money and get one that feathers nice and you'll enjoy using it!
