Old 10-09-2018, 04:43 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default Legal max speed verses max structural speed.
First let me say I’m not endorsing anyone exceed the manufacturers Vne speed. I’m just putting out this question as a thought experiment, after all we are building experimental aircraft. Why not have experimental thoughts to.
What if the RV-12iS was designed for a higher max speed then published (say 150 Knots) then it is current certified max speed of 120 knots. So with that in mind is this max speed being restricted by the FAA LSA rule or is it a hard design max speed?
The reason I ask this is due to the FAA possibility rumors of increasing there max LSA speed to 150 knots and max weight to 3200.
Anyone who built a EAB RV12 flown over 120 knots?
okay now that’s enough experimental thought. Everyone back to reality.
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
iS Engine Kit in work
iS Avionics Kit ordered
1st GEN FUSELAGE SOLD
Serial#12-0864
N112DR Reserved
VAF donation made for 2019
Old 10-09-2018, 05:31 PM
Does the FAA set the never exceed speed or maximum continuous cruise speed? Do not count on those FAA rumors coming true.
Joe Gores
RV-12 Flying
Old 10-09-2018, 05:52 PM
DBRuth DBRuth is offline
Default Never exceed speed
The RV-12 has a 136knot TAS never exceed speed if I remember correctly.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @207
Old 10-09-2018, 05:58 PM
Dave12 Dave12 is offline
Couldn’t have said it better!
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying/ For Sale
Old 10-09-2018, 06:10 PM
Default And...
That “thought” experiment could end in disaster if not just a “thought” experiment...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-10-2018, 10:30 AM
rcarsey rcarsey is offline
Right.. 120kt CAS is the maximum permitted cruising speed in level flight at sea level. Vne is set by Vans (by the engineers / design limits). You could definitely make some speed mods and get your cruise speed higher.. I think maybe what the real question is "what did vans do to slow the plane down [for meeting the LSA requirements] that i can [easily] undo?"
Old 10-10-2018, 11:39 AM
All the loads are determined, in part, by the speeds that the airplane is designed for. So while the FAA might establish something like the LSA rules, the designer, while keeping to them, designs the plane for the loads that those limitations impose.
Once the plane's design is frozen, they are very real things and really not a matter of the governmet's whim.
If you want a faster airplane, get a faster airplane.
Old 10-10-2018, 01:32 PM
AirHound AirHound is offline
Originally Posted by rcarsey View Post
Right.. 120kt CAS is the maximum permitted cruising speed in level flight at sea level. Vne is set by Vans. You could definitely make some speed mods and get your cruise speed higher.. I think maybe what the real question is "what did vans do to slow the plane down that i can [easily] undo?"
Do the rest of the RV models have thicker skins? If so, would that be a significant factor for + speeds and weights?
Doug
Old 10-10-2018, 01:33 PM
That’s funny... Last week we were flying the RV-12 back from a small airport 15 miles south. C172 departed ahead of us and announced right turnout and destination same as us. We scooted right behind him and turned inside his right-crosswind and set the GPS for home. End of story is we were on the ground and taxiing to the hanger when he was just showing up on downwind. We heard him say he was on downwind and then a pause… “I need to get a faster airplane”.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 419
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 10-10-2018, 01:55 PM
Default Speed
When it comes to max speeds, trust the engineers. TLAR engineering isn’t a good plan when dealing with potential flutter issues...
Bob
290 HP Barrett Hung
Wiring...
