Old 10-08-2018, 04:57 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Wheel pants alignmet ?
I am installing James pants on Vans gear and mount. The gear has toe in defined by the mount and gear factory drilled holes. The fuse is suspended so the gear is in the FLIGHT orientation. My question is, should the pants be skewed to face forward in the flight vector, or just equally squared with the axle direction ? If with the forward flight vector (ie: parrallel to the fuse centerline ), the pants wiil be significantly skewed from the axle nut seating for the outboard retaing bolt. Your thoughts ?
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 10-08-2018, 05:19 PM
I'd recommend calling the factory before proceeding. I don't think you want toe in; certainly not with any weight on the wheels.
Having said that, I'd want the pants to be aligned with airflow in flight.
Charlie
edit: To be sure we're on the same page, you're not talking about camber (angle from vertical), are you?
Old 10-08-2018, 05:34 PM
Suspended in the air (no load on the gear), the pants should be aligned with the direction of flight. The ground toe-in or toe-out is irrelevant. You're trying to minimize in-flight drag.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
