Old 10-08-2018, 02:15 PM
sglynn's Avatar
sglynn sglynn is offline
Originally Posted by boearl View Post
Steve, do you have photos? I’m do the magnetometer in the left wing.
My photos are on mykitlog.com/sglynn
http://www.mykitlog.com/users/displa...=253633&row=27
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 10-08-2018, 02:16 PM
sahrens's Avatar
sahrens sahrens is offline
I build a shelf similar to Dan's for a primary and secondary ADAHRS. Here is a link to that process, there are three different entries. http://www.mykitlog.com/users/displa...=194777&row=67
If I were to do it again I would fasten the shelf to the upright supports with screws instead of rivets. That way I could perform maintenance on the ADAHRS by removing the shelf, then removing the ADAHRS units. By riveting it I had to work in that small space of the shelf to attach the ADAHRS.
http://www.mykitlog.com/users/displa...=215240&row=39
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 10-08-2018, 02:39 PM
Raymo's Avatar
Raymo Raymo is offline
Default Simple...
I also have the Dynon adapter with the backup ADAHRS mounted on top.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 10-08-2018, 03:01 PM
wirejock's Avatar
wirejock wirejock is offline
Default ADAHRS shelf
I built a similar shelf to Dan's. Mine is bolted with aluminum and brass hardware to the two J-stringers and the F707 bulkhead. I have a drawing of you would like.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-08-2018, 04:19 PM
bruceh's Avatar
bruceh bruceh is offline
I built a shelf up high in the fuselage that attached to the stringers for the Dynon ADAHRS unit.
You can pop rivet it in place after you put the top skin on.
I also built a smaller forward shelf to support the tubing.
Use brass or aluminum hardware to mount everything.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 10-08-2018, 05:35 PM
Jpm757 Jpm757 is offline
If you mount the ADAHARS units towards the top of the fuselage and you are going with a slider, you will get magnetic interference when the canopy is opened. If the magnetomiters are aligned with the canopy closed you will be OK in flight, but ground ops with an open canopy will most likely result in compass error.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 200+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 10-08-2018, 07:14 PM
boearl boearl is offline
Thanks Dan.
Ken C.
Cancer Survivor
Retired Military/Retired Airlines
Been Most Ranks Once, Some Twice
RV-10QB kit bought and awaiting delivery
Founder: SAR (Some Assembly Required).
2018 Dues
Old 10-08-2018, 07:28 PM
jmra72a jmra72a is offline
I mounted the ADAHARS on the top just in front of the bulkhead aft of the baggage compartment wall. I mounted a bracket large enough for two ADAHARS the primary and the back up unit to sit on it. I also used all 316 SS hardware in that area s it wouldn’t effect the magnetometer. My testing showed that the magnetometer is working fine. I am pleased with it. I also installed the Advanced quick build panel with (2) 11” HDX units and the Avidyne IFD 540 to create an IFR panel.
Bill Wilson
Building an RV-7A
Old 10-08-2018, 07:56 PM
jcarne's Avatar
jcarne jcarne is offline
I literally just started doing this tonight. Here is what I came up with. This will go between the two J-stringers like many have done. Probably will use little brass screws to make it removable.
20181008_194240 by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
