Old 10-08-2018, 08:36 AM
boearl boearl is offline
Default Dynon ADHARS Installation?
Hi Folks, Looking to find someone that has installed the DYNON ADHARS. Iím a first time builder. I recently purchased a -7A Kit from an estate sale. Has a QB fuselage. Wings and empennage are mostly finished. Thinking I want to focus on the fuselage completion. I intend to use a Dynon quick panel, so I thought, now is a good time to work in the aft fuselage. Many Thanks, Ken
Ken C.
Cancer Survivor
Retired Military/Retired Airlines
Been Most Ranks Once, Some Twice
RV-10QB kit bought and awaiting delivery
Founder: SAR (Some Assembly Required).
2018 Dues
Old 10-08-2018, 08:40 AM
sglynn's Avatar
sglynn sglynn is offline
Default ADHRS
Hi, I mounted the ADAHRS in top of fuselage behind the bulkhead. And I installed Dynon Quick Panel. Everything seems to be working, but I'm not flying yet. Also if you want a backup you may want to add a remote compass. I ended up doing that later. Better to do it now while you are adding bracket for ADAHRS. Bracket for remote compass needs to be angled so it is orthogonal to the panel. ADAHRS doesn't. You can see it here.
http://www.mykitlog.com/users/displa...=253633&row=27
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 10-08-2018, 08:59 AM
Carl Froehlich's Avatar
There are a lot of ways to do this. I recommend you mind the guidance provided in the SkyView install manual on location. I tend to make a shelf between longerons (RV-8) or hang from the top of the fuselage (RV-10) and attached to the adjacent rib. One option if it makes sense for you mount is to get the Dynon plate so you can stack one ADHARS module on top to the other. If you plan on IFR at any point, recommend you get both the primary and secondary ADHARS modules.
Iíve never had a need for a remote compass for any SkyView install.
Old 10-08-2018, 09:43 AM
sglynn's Avatar
Default remote compass
A common backup is the Dynon D6 and it needs a remote compass.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
Old 10-08-2018, 09:50 AM
Sure - I had a single SkyView install with a D10A backup. The remote compass was not necessary but did make compass calibration for the D10A easier. Of note, just finishing an upgrade to this specific install that adds a second SkyView display. The D10A is being sold.
For a dual SkyView install the need for a backup is builder choice. I design with independent power for each display so a backup is not high on my list.
Old 10-08-2018, 09:54 AM
Jpm757 Jpm757 is online now
Ken,
I installed a quick panel in my -7 slider, and mounted the dual ADAHARS units piggyback in the center of the rear fuselage just aft of baggage bulkhead. I used 2 aluminum angles bolted to the longerons. There is no magnetic interference from the slider, but I did need to remake the shoulder harness cables out of stainless. Static ports are nearby, and system has worked very well. Search posts for various installation photos.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 200+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 10-08-2018, 11:04 AM
Thanks Jake. Do you have photos?
Ken C.
Cancer Survivor
2018 Dues
Old 10-08-2018, 11:05 AM
Steve, do you have photos? I’m do the magnetometer in the left wing.
Ken C.
Cancer Survivor
2018 Dues
Old 10-08-2018, 11:07 AM
Carl, I read the manual and will do as the “Borg” say: “I will comply.” ��
Ken C.
Cancer Survivor
2018 Dues
Old 10-08-2018, 11:13 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Photo
RV-7 behind the baggage wall.
http://www.vansairforce.com/communit...09&postcount=2
Dan Langhout
2019 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
428 hours and counting . . . .
Now based at Moontown (3M5)
