Old 10-05-2018, 04:23 PM
Norman CYYJ Norman CYYJ is offline
Default WTB full swivel TW
I am looking for a full swivel tail wheel to replace the old non swivel tail wheel on my newly acquired RV 4. It must fit the standard tail whell spring used by Vans. Any help appreciated.
Old 10-07-2018, 10:30 AM
RV-3 Pilot RV-3 Pilot is offline
Default Direct Replacement Tailwheel Kit
This link is for a Direct Replacement Spring/Tailwheel Kit. I used it on my RV and I’m very pleased with it.
https://vansaircraft.com/cgi-bin/sto...tailwheel-assy
DJ
RV-3 O-320/160hp
Old 10-07-2018, 11:59 AM
BobRv4 BobRv4 is offline
Default TW
If you buy a complete used spring and tail wheel assy it may not fit.
The spring was drilled "in assembly" so each one is different.
So buying a used already drilled one probably wont work.
You can just buy the swivel TW bracket then remove your spring.
It will need the end cut off, then someone to machine or turn down the shaft.
Reassemble the parts, then drill the swivel unit and tail spring, in assembly.
Make sure you keep it cleaned and well greased.
Old 10-07-2018, 02:24 PM
Thanks for the advise. I was going to remove the spring and put it in the lathe. I was hoping that someone out there might have a surplus assembly without the spring.
Old 10-09-2018, 08:27 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Contact Blake for anything related to the tailwheel.
He also has a tech sheet to hit the high points of swapping, converting, maintaining the tailwheels, springs, bolts, tapered pins, etc. Free for the asking.
http://www.flyboyaccessories.com/RV-...oducts-s/1.htm
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 10-10-2018, 04:56 AM
rbibb's Avatar
rbibb rbibb is offline
I have one of the Vans full swivel assemblies Id sell.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 10-10-2018, 09:21 AM
I am interested can you send me an email about it?
Old 10-10-2018, 10:25 AM
Cwood2000 Cwood2000 is offline
I just replaced my tailspring, wheel, fork, springs and everything else. If you lay the freight, I'll send it to you.
Aka YellaDawg
RV4
RV14 in gestation
Old 10-10-2018, 04:38 PM
Please send me an email about this. Thanks
Old 10-12-2018, 02:33 AM
Cwood2000@gmail.com
Sorry if my response is slow, we just had a hurricane and have no power, internet and cell is sketchy.
Aka YellaDawg
RV4
RV14 in gestation
