Go Back   VAF Forums > Model Specific > RV-4
Old 10-05-2018, 02:46 PM
smokyray's Avatar
smokyray smokyray is offline
Default Can it be true?
Originally Posted by RyanB View Post
I would therefore assume that the rivet spacing SK drawings became obsolete when pre drilled skins were released for the 4. Anyway thanks for all the help guys.
Ryan,
As a Jurassic RV4 builder who remembers drilling (and dimpling) alot of holes I am for once, speechless...
Say it isn't so...
V/R
Smokey
Old 10-06-2018, 02:21 PM
Bill Boyd's Avatar
Default Where I come from
it stands for Silent Key - which I hope not to become until I've finished this airplane.
Some days it feels like it's a dead heat.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 10-06-2018, 11:02 PM
RyanB RyanB is offline
Default Holes
You guys are making me feel bad😂
Only wing skins are predrilled, all ribs and understructure isnít. This also only applies to the wing, fuselage and empennage are still completely HOLE FREE 😄
Please donít throw me out the builders club
Old 10-07-2018, 07:36 AM
RussellT RussellT is offline
Hey Ryan you will always be a member of the builders club, your 4 will have those subtle little variations that all the 3's, 4's and early 6's have. It will show how you as the builder have interpreted Van's sketches and basic plans, you will have a flying machine upon which you will have lined out, spaced and drilled all the holes and solved the numerous issues as they become apparent, Your 4 will be unique and you built it. Build on...
Russell
RV 3B. Very slow build. At fwf & wiring..
Old 10-07-2018, 10:18 AM
Default RV4
Thank you Russell
We are really enjoying the challenge of the build and enjoying all the scratch your head moments that come with it! Itís gojng to be well worth owning the best flying 2 seat RV when itís all done
Old 10-24-2018, 08:17 AM
FinnFlyer FinnFlyer is offline
Had the same question.
See DWG 19 for rivet sizes.
One important thing (countersinking or dimpling spar holes):
Me: "I don't understand the rivet size (length) call outs.
Using a -3.5 to rivet .025 skin to 0.040 spar flange is OK. (0.025 + 0.040 + 1.5 x 3/32) x 16 = 3.29
But using a -4 to rivet .025 skin to .025 or .032 ribs. Why??"
Vans: "The difference between these is the way the components are prepped to accept the rivets in question. The skin to rib attachments would have both the rib and the skin dimpled where the skin to spar would have the skin dimpled and the spar countersunk. Some builders will choose to dimple the spar which would require a longer rivet be used. The illustration below may help you understand the difference.
https://drive.google.com/open?id=1nG...oAZLOLxYqN6gXp
In the end if a rivet does not seem to be correct it is easy to place one in a hole and measure the protruding tail to confirm if it is either correct or if you should make adjustments."
Finn
Hi everyone
On the wing plan it shows that for the wing skin rivet pattern we should refer to SK-31,32,33,34,35,36 and 37.
Any idea what SK stands for and where we can find these drawing or diagrams?
Iím probably missing something here
Thanks in advance
