Old 10-01-2018, 09:23 AM
Wiley Price Wiley Price is offline
Default Mount Skybeacon on RV6-A
Ok, I will try again: has anyone mounted a Uaviaonix SkyBeacon on a RV6-A?
The reason I am asking is the GPS antena must be vertical and the RV6-A wing tips are around 45 degrees from vert. This is also true for the new Skysensor.
If anyone has fabricated a mount, I would like plans, photo, or to purchase one.
Further, I would like to know how well the SkyBeacon and Skysensor work.
Old 10-01-2018, 09:51 AM
NewbRVator NewbRVator is offline
I was looking into this and seems like the Tail Beacon is the best bet but then there’s the Garmin suit too...
You roll the dice you takes your chances
Yearly dues paid 9/18
Old 10-01-2018, 01:34 PM
Ralph Inkster Ralph Inkster is offline
Vans used to sell little fiberglass fairings (wedges) that you glassed onto the old style wingtips to mount nav lights in the vertical position. Should be easy enough to fabricate, if you can't find someone with an unused pair lying around.
I gave the surplus pair I had to a 6 builder a few years ago.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 10-01-2018, 03:27 PM
Sam Buchanan's Avatar
been here awhile
This is how we did it back in the olden days:
Use floral foam and some plywood finished with fiberglass cloth and resin/filler and a bit of elbow grease to blend everything into the wingtip.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 10-01-2018, 03:55 PM
Larco Larco is offline
If you have the 600 series combo light you will loose the tail light portion of that light? But If you have a tail light in the rudder maybe you are good to go? Something to consider?
