Old 10-01-2018, 05:45 AM
JDA_BTR JDA_BTR is offline
When you buy it in the can does it come with some kind of straw like WD40 does? Seems the 190ml caulk tube is the easiest to use? This comes in a lot of different packages.....
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 10-01-2018, 01:28 PM
AX-O's Avatar
AX-O AX-O is offline
Originally Posted by RV-14E View Post
Forward baffle.
[/IMG][/url]
The above RTV strips seem counterintuative to me. In my head the RTV that is not touching the front of the fin would bulge inside the empty space between the fins. limiting the airflow.
Not only is there one "strip" of RTV, there are 2.
Van's instructions tell the builder to do that now?
Axel
RV-4 fastback thread and Pics
VAF 2019 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 10-01-2018, 05:16 PM
If the instructions are followed, the RTV stripes will only be about .030 thick.
Enough to help prevent fretting wear, but not enough to cause any air blockage or leakage.
Scott McDaniels
Hubbard, Oregon
Old 10-01-2018, 08:59 PM
DanH's Avatar
DanH DanH is online now
I dunno 'ole buddy. If the stripes space the wraps away from the fins by .030", there's a .030" wide leak gap along the side edges.
If the goal is to stop fretting and keep all the air where it belongs, gasket the whole inner surface of the wraps.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-02-2018, 09:09 AM
It is a very small amount of surface area coated with a very flexible/compressible material.
My experience is that with the wraps pulled tight it has no influence but I imagine an even coating as in your photo would be the optimal plan.
Especially if you are measuring gaps with a feeler gauge
Scott McDaniels
Hubbard, Oregon
Old 10-02-2018, 06:30 PM
czechsix's Avatar
czechsix czechsix is offline
Dan, what kind of material is that? Did you still place the aluminum wraps over the top of it?
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 10-02-2018, 07:43 PM
VA Maule VA Maule is offline
Default Material?
Kinda sorta looks like duct tape to me .
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 10-02-2018, 08:48 PM
wjb's Avatar
wjb wjb is offline
From a previous DanH post: it's 9 oz glass impregnated with Permatex - put in place wet. The aluminum baffles go over this, per plans. I'm baffling my IO-360 now, and have been scrubbing all relevant posts.
SUPER thanks go out to DanH for his wonderful posts on this subject!
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 10-02-2018, 09:12 PM
Yep, I'm really glad I opened this can of worms.... a lot here....
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 10-02-2018, 09:14 PM
DanH's Avatar
Yep, Loctite 598 or Permatex Ultra Black, same product. Roll it into the cloth between two sheets of 4 mil plastic. Cut the exact shape you wish to apply. Peel one side, stick it to the fins. Allow to cure, and only then peel the plastic off the outside.
When fastening the aluminum wraps into place for the final time, be sure to run a small bead of sealant across the the top , so air cannot flow between the aluminum and the outside of the fiberglass/silicone gasket. That would be a really useless leak.
Dan Horton
RV-8 SS
Barrett IO-390
