Old 09-29-2018, 09:02 PM
Jimbot Jimbot is offline
Default No RV-9/9A plan “gotchas”?
I’ve always wondered: Has anyone ever discovered any RV-9 / RV-9A plan “gotchas”? Unlike some of the other RV models’ model-specific threads, I don’t see a permanently-posted “gotchas” listing for the 9/9A.
My EAA chapter is working on a 9A build project, and we’ve come across a few things so far in the midst of building the fuselage.
Thanks to all the RVers out there for all of the great comments/feedback on this website - y’all are greatly appreciated!
Jim Hall
2018 VAF Annual Dues Paid
Former President, EAA Chapter 309 - EAA 309
Founder, SUPERBIRD Aircraft & Automotive Cleaning Products, featuring the SUPERBIRD Paint Restoration System
https://www.superbirdclean.com/colle...-force-members
Old 09-29-2018, 09:38 PM
Default Just me
I just used the rv7 gotchas for the fuselage and engine stuff. For the wing and tail there arent many; what there are are covered very well in the “ overthehill “ build log.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 09-29-2018, 09:47 PM
N941WR's Avatar
N941WR N941WR is offline
Jim,
You should have stopped by NC26 this afternoon as I was there with my -9.
Follow the instructions and you will build a nice plane.
The only"gotcha" I can remember was there was no drawing or dimensions for the piece of aluminum that connects the angled channel that goes from the back brace down to the floor that covers the flap motor. It was easy enough to make.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-01-2018, 05:12 PM
Hey Jimbot,
The rudder stops didn't seem to work for mine when done per plans. Just make them oversize and keep filing/cutting until the rudder comes with about 1.5" of contacting the elevators. Some builders like to use the Delrin internal stop.
Send me a pic or two of your progress when you get a chance.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2019
Old 10-01-2018, 05:28 PM
Jim I didn't find any. The drawings/manual were well written back in 2006. I didn't make any modifications everything stock everything by the plans no "gotchas"
Old 10-01-2018, 05:52 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Yes
Here is a gotcha. I mounted the electric fuel pump (facet) on the fire wall according to plan. I found it to be to low and had a difficult time making a tight 90 deg bend of the 3/8 aluminum tubing while also having to make a flare in the tube. My suggestion is to make the 90 deg bend/flare in the tubing first and this will determine where to best mount the pump. (Higher off the floor than the plan suggests)
Al Girard, Newport, RI
N339AG
RV-9
Old 10-01-2018, 06:31 PM
N941WR's Avatar
After trashing a bunch of tubing, I put a Banjo Fitting to make that turn.
Bill R.
SC86 - Easley, SC
Old 10-03-2018, 08:51 AM
Hi Guys,
Thanks for all of the great feedback! I will be sure to check out the 7/7A plan "gotchas" to see if things in certain situations apply to the 9/9A.
Jim Hall
Old 10-03-2018, 02:52 PM
wirejock's Avatar
wirejock wirejock is offline
Default Gotcha thread
Ask the Moderators for a thread. That's what I did. Next day it magically appeared.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
