Old 10-05-2018, 03:17 PM
rv8ch rv8ch is online now
Default PDF diagrams
Van's has a really useful document here:
https://www.vansaircraft.com/public/...4/WH-00125.pdf
Mickey Coggins
http://rv8.ch
Old 10-05-2018, 03:53 PM
N941WR's Avatar
N941WR N941WR is offline
Before you order anything, make a list of all the electrical things you want and the expected amperage draw.
Once you have that list made and know how many amps each item will require, you can start designing your electrical system. The good news for you is that some of the LED lights and strobes hardly draw any power.
Here is a partial list. You will have to add and/or delete the things you want in your plane. Remember, the more things you add, the more complex and heavier the plane becomes. It is up to you to figure out which items you can combine and which you want to stand alone. For example, with my Taildragger, the landing and taxi lights are on separate breaker switches because I need one with the tail down and both with the tail up. You could combine this to one three position switch and a separate breaker but I just used two breaker switches.
Landing Light
Taxi Light
Strobes
Position Lights
Interior Overhead Lights
Panel Lights
Pitot heat
EFIS 1
EFIS 2
AP Roll Servo
AP Pitch Servo
Audio Panel or Intercom
ANR Headset Power
Radio 1
Radio 2
Transponder
ADS-B
Nav GPS
VOR/ILS
Backup GPS (Handheld)
Backup EFIS
Backup Radio (Handheld)
Flap Position Indicator
EICommander (Sorry, had to add that!)
Left Ignition
Right Ignition
Starter
etc.
Good luck!
PS. I used Microsoft Visio to draw my schematics, available on my website. it is a great tool for these things.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-05-2018, 04:38 PM
KRviator's Avatar
KRviator KRviator is online now
Originally Posted by buchaneer View Post
Hi,
Anybody got any basic wiring schematics and layouts for a RV9A
Not decided on avionics or panel yet but want to put together some wiring looms for wings and rear fuselage which contain the needed cables and nessesary wiring sizes.
Have purchased 18 and 22 AWG wire to make them up from but looking to advice of what equipment to include supplies to. Will have pitch and roll servos fitted and electric trims controlled from sticks.
Any advice welcome and some installation pictures as to routing and position if available. Looked on the forum before but couldn't find too many pictures.
It really depends on what you want to install, though you can run looms for things like nav lights and trims through the wings and tailcone, that's fairly standard.
I used a free online schematic generator from Digikey to produce my drawings. I have a single-screen SkyView system, VP-X and only a KLN-90 for navigation (not shown, it's a recent addition). You can download the original size HERE
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 10-05-2018, 11:08 PM
Default Nice drawing
That's a very clean drawing - wow. Well done.
Mickey Coggins
http://rv8.ch
Old 10-05-2018, 11:24 PM
pilotkms pilotkms is offline
Default Steinair
Figuring out the wire runs between all of my components had me stumped. Dual Skyview, GTN 650, SL40, VPX, ...... Analysis paralysis for sure. Contacted Stein (where I purchased most components) and he advised they could provide me a wiring diagram of my WHOLE plane. That was 5 years ago & believe it was $125. Best $125 spent.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now @ KPXE
270+ Hours & 5x cross the USA
2018 OSH - yes
Old 10-06-2018, 04:32 AM
RicoB RicoB is offline
Now days its in the $400 range(avionics) I did have them draw out my avionics and it was the best thing I ever did.
Rico Burgos
RV9a at KWHP
C-150 at KMOD
Old 10-09-2018, 03:12 PM
buchaneer buchaneer is offline
Default Wiring schematics for RV9A
Thanks to all of you for your replies it has certainly got me thinking.
A great deal of info to get me started, much appreciated.
Only one issue I have when using this site as a resource is when you view older posts some or all the photos have disappeared/expired and to quote the proverbial " a picture speaks a thousand words" has been lost.
That said This place is great to point you in the right direction whatever your issue.
Duncan Kenworthy
QB RV-9A Tip-up (has become slowbuild !!)
Tail feathers done! Working on the rest!
Reg number reserved: G-RVSK
Donation made for 2018
