Old 09-29-2018, 10:41 AM
todehnal todehnal is offline
Default Intercom Volume Level Problem
I have an intercom volume level issue. This is not new. It’s just that I would really like to find my problem. First, I have matched David Clark headsets, an SL40 transceiver, and 403 intercom. I think that I can eliminate the SL40 since the problem exists even with the avionics switch in the off position.
Both headsets have individual volume controls for left and right, but the left has much more volume than the right on both headsets. I must set the left ear to midway, and the right to full volume in order to get a reasonable balance between left and right, and that is on both headsets. That can’t be normal!
I am leaning towards the pots on the AV50,000, but I am not sure where to start. By the way, this is a conversion harness system, but I can’t imagine that it matters. Any thoughts or ideas would be greatly appreciated…….Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 09-29-2018, 12:00 PM
You can ask for help here... VAF Forums > Avionics / Interiors / Fiberglass > COMM
http://www.vansairforce.com/communit...splay.php?f=38
The guys are very helpful...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 419
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 09-29-2018, 12:24 PM
Cannon Cannon is offline
I had to do lots of tweaking on the pots of the AV5000 to get everything working happily on our RV-12. Hereís the relevant section.
http://www.vansaircraft.com/pdf/revi...ection_42D.pdf
This thread may help as well. Itís long, but eventually discusses the AV5000 pots.
http://www.vansairforce.com/communit...highlight=Pots
1976 C-185
1947 J3C-65
RV-8 project
Old 09-29-2018, 05:59 PM
Thanks guys. Now I have a place to start. Really appreciate the help. Iíll be sure to post my progress and hopefully the fix. ....... Tom
