Old 09-28-2018, 09:42 AM
JBHansen JBHansen is offline
Default Blue Plastic
How do you remove pieces of the blue plastics that comes on the sheet metal? I some of them that have been of the metal for three years?
Old 09-28-2018, 10:37 AM
DaleB's Avatar
DaleB DaleB is offline
For smaller pieces I just peel it off from a corner. Larger pieces, like wing and fuse skins, I used a length of dowel or PVC pipe. Peel up an edge, tape it to the pipe/dowel if needed, and roll it across the skin to roll up the film around your chosen rolling implement.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 09-28-2018, 10:54 AM
Brantel's Avatar
Brantel Brantel is offline
Heat it with a heat gun or hair drier. It will ease the pain.....
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-28-2018, 02:19 PM
flion's Avatar
flion flion is offline
If you're not in a huge hurry, just put the part in the sun. I found this to work even in the wintertime (sorry for those of you in the so-called Midwest, in Arizona we have sun in the winter, except on the days it snows). Using a pipe or paper tube to roll up the plastic on larger parts is a nice idea. If you dimple before peeling (in order to avoid the dies scratching the alclad), be sure to check all the dimples for leftover plastic. The dimpling process can cut the plastic at the edge of the dimple, leaving you with little 'O's of plastic.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 10-04-2018, 12:36 PM
Thanks all.
Old 10-04-2018, 12:44 PM
JwWright57 JwWright57 is offline
I like the sun idea i have to try that
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit in progress
Dues paid 2019
Old 10-05-2018, 12:27 PM
The heat gun worked very well. Thanks for all the replies.
Old 10-11-2018, 08:19 AM
BigJohn BigJohn is offline
Took me a while to figure out how to get this picture inserted, but here it is better late than never. On the OWW project these two novice volunteers figured out the best method of plastic removal very quickly. Note that the project manager was keeping a watchful eye on them!
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
