Old 09-27-2018, 08:26 PM
llohrman llohrman is offline
Default F-615 thru F-619 seat rib trim
Anyone remember if they had to trim F-615, F-616 and F-617 (left and right) seat ribs. The aileron push/pull tube rubs on the forward edge of the lightening holes with the stick in the elevator up position. I have trimmed F-618 and F-619 per plans for the control stick weldment but couldn't find anything on the others.
Thanks!
Old 09-28-2018, 08:07 PM
DavidAhrens DavidAhrens is offline
normal to clearance large lighting holes for slight interference of aileron control tubes, if you need to remove more than 1/8" or so you may want to recheck the mount height of the controls to spar mount bracket.
