Old 09-27-2018, 04:19 PM
n38139's Avatar
n38139 n38139 is offline
Default Cowling fasteners?
Anybody used something beside the piano hinge on the cowling sides to keep the two pieces together? I was thinking of something like a zeus type fastener.
Steve
Old 09-27-2018, 04:30 PM
terrye terrye is offline
Lots of discussion about this, use the search function. Dzus fasteners are probably not a good choice. Best choice seems to be with either Milspec or Skybolt
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 09-27-2018, 04:43 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Plus1 for Skybolt.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
Old 09-27-2018, 04:51 PM
rocketman1988 rocketman1988 is online now
Default skybolts
skybolts+1
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-27-2018, 05:25 PM
Carl Froehlich's Avatar
I never liked the look of Skybolts or other such fasteners and have always used hinge material - but this is builder preference so decide what you want.
I note however that the lower cowl hinge should be replaced with the more robust extruded hinge (MS20001) or aluminum plates with nutplates.
Old 09-27-2018, 07:57 PM
Deweyclawson Deweyclawson is offline
Default skybolts
skybolts + 4
Dewey Clawson
Super Sabre Society
2012 RV10; 1993 RV6A; 1947 Cessna 140, in progress
2019 dues exempt but paid anyhow
F100, A7D, A10, F16,
Fokker, Boeing, McDonnell-Douglas
Old 09-27-2018, 09:09 PM
Timberwolf Timberwolf is offline
Skybolt’s are nice, but for the price and pain of installing them in a cowling with the engine already mounted and cowling painted, I would go back with a piano hinge in a heartbeat. The piano hinge is cleaner, lighter, cheaper.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P in progress
Aero Engineer, A&P
Old 09-27-2018, 09:38 PM
Tommy123 Tommy123 is offline
Default Camloks
I went with cam locks.
Old 09-28-2018, 06:02 AM
wilddog wilddog is offline
Use something other than hinges across the top firewall and bottom by exhaust.
Old 09-28-2018, 09:52 PM
bifft bifft is offline
I started with the hinges, but then after many times spending several hours trying to get the last few inches in I said, quite literally, "screw it". Replaced the last nine inches with countersunk screws and tinnerman washers going into nutplates. Also used them for the bottom of the cowl.
