Old 10-01-2018, 10:17 AM
jabarr jabarr is offline
I took my commercial check ride in a Colemill 310. If done as rocketman describes, it is a very dangerous maneuver if an engine fails as the extreme pitch angle and slow speed would certainly lead to very bad results. We went to the examiner and explained the problem and he had no issue with doing exactly as rocketbob explains.
Just ask the DPE what is acceptable—
As the first sentence in Doug’s quoted description states, it is now a planning, orientation, coordination, and timing exercise.
Old 10-01-2018, 10:22 AM
Default and...
...and that would be the exception to the rule. Most people don't do their commercial ride in a Colemill 310. Great airplane though!
...and asking the DPE what he/she considers acceptable is never a bad thing.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-01-2018, 12:00 PM
rocketbob's Avatar
rocketbob rocketbob is offline
The commercial ACS spells out the rules and parameters, very specifically, for the checkride maneuvers. Nowhere does it state chandelles are started at Va.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 10-01-2018, 12:51 PM
Default The ACS says...
The ACS says appropriate, yes...however...
Referencing the appropriate additional FAA resources, as ALL good instructors should:
From the official FAA "Airplane Flying Handbook", Chapter 9:
Where it specifically states entry at Va, maneuvering speed...yes, you will target the "manufacturers recommended speed"...however...Va is selected for a good reason. That is another discussion.
Bob
290 HP Barrett Hung
Wiring...
Old 10-04-2018, 07:36 AM
Plumbmaster's Avatar
Plumbmaster Plumbmaster is offline
Default My Two Cents Worth
Well yes, if dong it for a commercial check ride, of course it should be practiced, explained and performed by the book. If using the maneuver to get out of a box canyon, depending on the winds, less speed will provide more room and a shorter turning radius to get out of the canyon. It makes sense to apply full power and significant up elevator AFTER one gets the nose turned away from the initial direction of flight.
Flying from my computer in Hong Kong after being censored in the PRC...
Ron Lem
"Stubbs"
1995 RV6A N89PC Bought In 2018
160 HP O320, CS Hartzell Prop
2018 Dues Paid
Old 10-04-2018, 08:49 AM
eaglen92ce eaglen92ce is offline
I suspect that the ACS saying "appropriate" speed means that the entry speed chosen is part of what the examiner is evaluating. The DPE is expecting Va entry, if the applicant started from Vx or dove to achieve Vne prior to starting the maneuver, then the applicant did not chose the appropriate speed. Best to ask the DPE before the flight if you have a plan to use a different speed.
Bill York
Stellar Airpark (Chandler AZ)
RV-6 N477DH
Eagle II N92CE (sold)
Hiperbipe N777HT (sold)
PA22-160 N9322D (sold)
