Old 09-26-2018, 09:59 AM
merlin3 merlin3 is offline
Default Gear leg fairings and intersection fairings.
Hi I just bought an rv6 that needs a little work. One of the first things. I would like to do is fix the gear leg fairings. At this point i think it would be easier to just order new gear leg and intersection fairings but wondering which ones are the best to go with. After searching i found a couple different companies make the intersection fairings but is vans the only one thay sells the gear leg fairings? Which are best? Tia!
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 09-26-2018, 11:04 AM
Raymo's Avatar
Raymo Raymo is offline
My hangar mate recently replaced his RV-6 metal leg fairings with Vans fiberglass. They fit well and did not need much fitment work.
After seeing the quality, I wish I had gone that route instead of more expensive intersection fairings from another vendor.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
